January 29, 2026, 03:36:33 AM *
Author Topic: Tire Pressure  (Read 1966 times)
steven
« on: July 14, 2009, 07:45:07 AM »
I just had Ellite 3 tires installed on my 2000 STD.  What tire pressure should I have in the tires?
« Reply #1 on: July 14, 2009, 09:10:37 AM »
I run 40 in the front and 42 in the rear and always get over 20K miles on the Elites
Old Geezer Richard
San Antonio , Tx
« Reply #2 on: July 14, 2009, 09:37:09 AM »
Hey Steven , depending where you live and how hot it gets there , I ran my front avon cold at 38 because it  will heat up to 40 lbs where I want it ... in the cooler months I air it up to 40 for the winter and leave it there .... when I had a M/C tire on the rear in the hot months I ran 40 lbs because it heated up to 42 lbs ... again in the cooler months I aired it up to 42 lbs and left it there ... I found that more than 40 lbs on the front was a harder ride for me .... Thanks Old Geezer
« Last Edit: July 15, 2009, 09:51:44 AM by OLD GEEZER » Logged
Spirited-6
Nicholasville, Ky.
« Reply #3 on: July 14, 2009, 11:21:13 AM »
Steven, Welcome to VRCC. Great place to be.  cooldude
Spirited-6
steven
« Reply #4 on: July 15, 2009, 07:17:39 AM »
Thank You for your information.  Leaving Friday to ride the Easten side of Lake Michigan.
