January 29, 2026, 03:36:47 AM *
Author Topic: Tires don't leak!  (Read 1976 times)
FLAVALK
Winter Springs, Florida
« on: July 15, 2009, 04:54:47 AM »
Installed a new Avon Cobra on the front about 3 weeks ago and for the first time since I owned this bike (over nine years), neither the front or rear tire leaks air! Thats a first for me.
The old front Venom that I replaced would leak about 2-3 psi/week. The rear Venom that I had before the one thats on the bike now also would leak about that much. So did the Metzlers and the Dunlops. I started thinking it was my wheels  Sad
Anywho, my Valkyrie just became a bit more maintenence free. Now, if it would only stay clean........ Wink
Dennis Klinefelt
« Reply #1 on: July 15, 2009, 07:48:15 AM »
I changed to steel valve stems awhile ago and noticed that my tires don't need air as often..the steel stems are double nuted for a tighter fit than the stock rubber stems ..also when changing tires I clean the the rim where the bead seals with a drill and wire wheel..rock on...
FLAVALK
« Reply #2 on: July 15, 2009, 08:10:33 AM »
Yes it does make a difference. I should have noted that I went with the metal stems also
« Reply #3 on: July 15, 2009, 01:31:34 PM »
+1
Thanks Dalai who cleaned the bead really well when he put on my cobra rear tire
Hasnt lost one lb of air since April
Glad you are a happy Valker now
