February 07, 2026, 08:22:58 PM *
Author Topic: fuel line replacement  (Read 2356 times)
quirkyguy001
finally found a way to hold the dragon back
Tulsa, Ok
« on: October 07, 2013, 04:03:33 PM »
any suggestions on a good info source for replacing all the hoses on my 1998 valk? Dealer wants over $1000 to do it
Used to buy new bike every two years. Can't find anything to upgrade to. Harley rider for 40 years. Nough said
saddlesore
« Reply #1 on: October 07, 2013, 05:57:35 PM »
A couple of suggestions... Go to the home page here and click on shop talk there's a lot of info there you'll need, like removing the gas tank and air box etc.
You'll also find the tech forum where you can search for particular projects.
I'd give you some links too but I lost a lot of stuff sending data to a new computer.
Good Luck Smiley
DARE TO BE DIFFERENT
« Reply #2 on: October 07, 2013, 06:25:12 PM »
Most of the lines MOST NOT all are vacuum lines. A lot of folks here have gone the de-smog route. There is a LOT of information on de-smog and fuel line replacement. Good luck with your quest. RIDE SAFE.
Michvalk
Remus, Mi
« Reply #3 on: October 07, 2013, 07:07:34 PM »
Or you could get the tubing and a set of long needlenose and change them yourself. You can change most of them without tearing anything down if you take your time. The dealer just didn't want to do it, hence the outrageous price cooldude
« Last Edit: October 07, 2013, 07:11:00 PM by Michvalk » Logged
cma1
« Reply #4 on: October 07, 2013, 07:27:40 PM »
listen to these guys, they know what they are talking about.$1,000.00 ?????????????? damn, were you getting new tires and a mustang seat out of the deal ?
its pretty easy to do yourself, a few feet of bulk vaccum hose and an afternoon. I have done the long needle nose method, works fine with the intakes off, I found a straight pair of forcepts work a bit better.
vranasaurus
KCMO
« Reply #5 on: October 07, 2013, 08:50:58 PM »
For $1000 they better have the common courtesy to give you a reach around.
« Reply #6 on: October 07, 2013, 09:43:58 PM »
Cut ya a deal-come on down to the Ozarks and i'll git er done fer $800.00 NO reach around but i'll give ya the 2nd ex ole ladies phone #.  2funny RIDE SAFE.
« Reply #7 on: October 08, 2013, 01:31:30 PM »
I notice you're in Tulsa.  If you're opposed to doing it yourself check out the Attic Rat.  He knows Valkyries and he also is in Tulsa.
« Reply #8 on: October 09, 2013, 03:45:44 AM »
And the fuel lone new from Honda is under $15.  Gotta pull the tank to get to it.
Attic Rat knows his way around a Valkyrie for sure.
Hay Cool
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #9 on: October 19, 2013, 03:41:11 PM »
Thanks guys for the referral quirkeyguy001 came by today and we put together a plan to get him fixed up. What he was referring to was the o rings on the fuel rail. Looks like we will do the performance work on his bike too.
quirkyguy001
Tulsa, Ok
« Reply #10 on: October 19, 2013, 04:34:09 PM »
As Atticrat said I will be leaving bike off for his performance deal.  Looking forward to the changed bike and I am totally happy with it now.  After seeing what he does with  bikes I will have a permanent smile on my face. Just think he is only 7 minutes from my house. Yahoo
