November 25, 2025, 10:02:25 PM *
Author Topic: Need repair for Stiff grabby Front Brakes  (Read 1133 times)
Chaosandconfusion
Tallahassee, FL
« on: October 08, 2013, 07:33:44 AM »
My front brakes work well, but the brake handle is stiff and hard to pull.  When I use the front brake they are grabby when moving slowly.   Since these are hydraulic brakes I was think that it might be the brake calipers or the master cylinder.
Has anybody had a similar experience?  How did you resolve it?
On a comparable note, the Clutch handle is hard to pull, is there a way to adjust that too?
or Maybe I need to work out more uglystupid2
Thanks in advance.
Ride Long and contemplate
« Reply #1 on: October 08, 2013, 07:41:28 AM »
Remove the lever and clean and relube the pivot pin with a waterproof grease. Then do the clutch lever too.
« Reply #2 on: October 08, 2013, 07:55:38 AM »
Not only clean and lube that brake handle, also look closely at the curved "foot" portion that contacts the end of the push-rod of the master cylinder.  If its not really smooth, use some emory cloth to smooth it before lubing and things will be much improved.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: October 08, 2013, 09:07:36 AM »
And, it's possible to bind the lever by tightening the pivot post/acorn nut too much.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
pancho
Bonanza Arkansas
« Reply #4 on: October 08, 2013, 03:43:00 PM »
The information on this site constantly amazes me...... I have had this same problem since I have had my bike on the road,, I have been through the calipers twice and made sure cups, pins and sliders were all working smoothly, had the lever off and worked with the master cylinder piston, cleaned and lubed the pivot without fixing it. Somehow I had never looked at the part of the lever that contacts the push rod like Chris suggested. Pulled it, took some emery cloth to it, lubed it lightly, problem gone....
Five minute fix for a problem I have been chasing on and off for months...... and in hindsite, it always felt like it was coming from the lever, go figure.
« Reply #5 on: October 08, 2013, 04:24:45 PM »
Good Job Pancho
Chaosandconfusion
Tallahassee, FL
« Reply #6 on: October 10, 2013, 07:50:19 AM »
I always thought that 7759 minds were better than 1.  Grin
Thanks for the help I will work on it tonight.
sawdustar
Conway, AR
« Reply #7 on: October 10, 2013, 10:10:39 AM »
+1..!!!!!
Thank You,
Dennis
john
tyler texas
« Reply #8 on: October 10, 2013, 03:48:09 PM »
                coolsmiley                    " Five minute fix for a problem I have been chasing on and off for months...... and in hindsite, it always felt like it was coming from the lever, go figure "
                                                             don't cha love this site ....         cooldude
vrcc # 19002
