November 25, 2025, 10:05:35 PM
Anything else it can be?
Topic: Anything else it can be? (Read 777 times)
BamaDrifter64
Athens, Alabama
October 09, 2013, 04:36:53 PM »
Had my carbs rebuilt in the spring as the bike had sat for awhile. 2000 Std., 25k miles. It continued to sit after that until just now. It wasn't running great. Left side had a lot of pops, backfires. Idled about 300 rpm. It has been desmogged. I took all the intakes off so I could adjust the carbs as it seemed to run really rich. They had adjusted them to 3 turns out, I adjusted them to 2.25 turns out. Snugged all the bolts and screws up, tightened the exhaust nuts, runs much better, but still have some popping out the left side. Desmogged, so shouldn't be any vacuum leaks. Tightened up the intake and exhaust fasteners, so I wouldn't think that would be the cause. What else could be causing it?
Dave
http://vrcc.photostash.com/vrcc_24883/photo(1).JPG
http://vrcc.photostash.com/vrcc_24883/photo.JPG
cma1
Re: Anything else it can be?
October 09, 2013, 06:20:31 PM »
try tightening the exhaust headers up, but carefully the torque setting is like 8 lbs. then try tightening the rubber intake flanges, that said, mine pops on the right side, always has, so I consider it charm
whitestroke
San Pedro, Ca.
October 09, 2013, 06:42:06 PM »
If it ran good after carbs were rebuilt, you need to start with a can of fuel injector cleaner per tankful of gas. Do that a few times and If that doesn't work your looking at carbs being rebuilt again.
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
Red Diamond
Beaumont, Texas
October 09, 2013, 06:43:32 PM »
Once you adjusted the pilots to 2.25 turns to get rid of that rich smell, did you resync the carbs?
=> InZane XXV
