February 07, 2026, 10:14:31 PM *
Author Topic: beating the dead horse  (Read 982 times)
N0tac0p
« on: October 15, 2013, 11:08:33 AM »
well shortly i'll be pulling the rear and do my exam, relube, etc.  the drive shaft and pinion, did we ever get anywhere with that?  concerned if i put too much moly, it will plug something or not enuf moly and it will wear the spline?
I have typically used the honda moly on everything in the rear gear cluster, but i have read of various witches brews there that folks put together.  is that used everywhere, even in the pinion?  ujoint,  etc?
best concoction?
9Ball
« Reply #1 on: October 15, 2013, 01:05:40 PM »
follow the manual...they even specify the amounts needed in grams.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #2 on: October 15, 2013, 01:09:52 PM »
Everyone has their way to do it. I use a good quality water-proof grease. The holes in the drive shaft cup don't seem to work as intended, some get oil to the cup others do not. I just make sure there is grease in the cup and on the drive shaft. The last time I did this work I added a bit of drive oil to the cup along with a new seal.
I always thought everyone put the grease in the female as well as on the male counterparts of both drive systems, but, Chris [ Jeff ?] made it public here which was a good thing for him to state.
Some folks want to make sure they lube everything just as Honda states, thats fine but I don't worry about that too much. I just make sure everything that should be well greased, is.
« Reply #3 on: October 15, 2013, 02:03:15 PM »
You're right, it is beating a dead horse. The search function will help you find a whole herd to test your flagellating endurance with.
