February 07, 2026, 08:22:05 PM *
Author Topic: I got me a new toys for my shop...  (Read 1975 times)
BigBF
Text message at 602-332-4872
Phx AZ
« on: October 20, 2013, 07:34:47 PM »
It's the Carburetors Synchronize.
My son heard it before and after, he said sound lot smoother...  cooldude cooldude cooldude cooldude cooldude cooldude cooldude cooldude
Before
After
jeepman357
Glendale, Az
« Reply #1 on: October 20, 2013, 08:16:06 PM »
Hey Bill, does this mean i need to bring my Valk back and have the carbs re-synched? LOL
Liberalism is a mental disorder.
PhredValk
Edmonton, Alberta, Canada
« Reply #2 on: October 20, 2013, 09:25:09 PM »
Wow, over $600 each!
Fred.
VRCCDS0237
« Reply #3 on: October 20, 2013, 10:15:43 PM »
Ooooh! Purddy lights, I like those.
Phred, where did you get the price from?
BigBF
Phx AZ
« Reply #4 on: October 21, 2013, 01:05:52 AM »
You have a 7 cylinder valk!  Shocked
Nope.... #1 on both gauges, are coming from carb #3 with Tee/hoses, then left side gauge is carb #1 for 2, carb #5 for 3, and  right side gauge carb #3 for 1, Carb #2 for 2, carb #4 for 3, carb #6 for 4.
BigBF
Phx AZ
« Reply #5 on: October 21, 2013, 01:15:35 AM »
If you want to. Text me...
BigBF
Phx AZ
« Reply #6 on: October 21, 2013, 01:19:58 AM »
Fred.
Yup got good discount in local. Retail for $739.95. I don't want to risk pay that much over online....
BigBF
Phx AZ
« Reply #7 on: October 21, 2013, 01:20:57 AM »
Yup more than awesome  cooldude
Tailgate Tommy
Fort Collins, Colorado
« Reply #8 on: October 22, 2013, 02:45:51 PM »
Very cool. Next time I'm in AZ, I may look you up.
You removed myIS's rounded off and stuck rear diff plug at Inzane this year. Thanks once again!
Tom
BigBF
Phx AZ
« Reply #9 on: October 22, 2013, 03:57:09 PM »
Tom
Sure... And Your welcome...
JetDriver
Columbus, OH
« Reply #10 on: October 22, 2013, 08:14:32 PM »
You were already pretty good ( cooldude) at syncing carbs.  Was the "before" pic a bike you had manually synced previously.  What I'm asking is, are your new tools that much better at syncing then what you were already doing?  It looks like it's probably a faster way for you to do it anyway.
BigBF
Phx AZ
« Reply #11 on: October 22, 2013, 09:34:12 PM »
Had one to recheck few months ago and recently was little off only like 1/8th turn obviously it's pretty picky. Yes more quickly too it also will tell me if in stake or exhaust valve is leaking or not. Pretty cool... Will see in future if that happen and will adjust the valves then run it and see if that does tells.
mmurffy03
03 standard
toms river new jersey
« Reply #12 on: October 23, 2013, 09:38:54 AM »
have you ever run the pilot screws just 1 turn out ? with a k&n and pipes desmoged
I have 2 four gauge sets one is the Honda OEM set the other is made by K&L I wonder how close they might read out to something that accurate I also got some new toys a dual 6 inch buffing wheel a 6hp 30 craftsman compressor and a table top sand blasting cabinet I was glad my compressor fit in my extra garbage can holder on the side of my house so my 1 car garage is a bit quieter and more room too after buying about every chrome part I could find I am now changing my look to polishing all my parts to look plated and the bike looks better and cleaner with less add on parts and the original parts polished up less is more it was a bit cluttered before
« Last Edit: October 23, 2013, 10:01:14 AM by mmurffy03 » Logged
BigBF
Phx AZ
« Reply #13 on: October 23, 2013, 01:29:35 PM »
Got picture of your two gauges?
Pilot 1 turn out is a bit too much. Usually 1/4 to 1/2 turn out is about right.... What mpg are u getting at? At average 65-75 mph
BigBF
Phx AZ
« Reply #14 on: October 24, 2013, 07:30:19 PM »
Nice and in rear end is pretty low so be careful run over speed bump or ramp that will damaged your crossmember frame from hit on side stand bracket.
mmurffy03
03 standard
« Reply #15 on: October 26, 2013, 01:47:44 AM »
to run the long pipes I need to install the stock 13 in OEM shocks or risk draggin them but damm they look good like that
I have a set of slide on shortie canisters for the 11 in progressive shocks two brothers makes several canisters that fit the headers and all can be packed for the level of noise and backpressure you desire for the mood you are in with just removing and replacing a few rivets on the back of the canister
these are the gauges I have
the Honda set works fine but the K&L set seems more accurate a higher quality gauge
« Last Edit: October 26, 2013, 09:07:14 AM by mmurffy03 » Logged
« Reply #16 on: October 26, 2013, 08:59:11 AM »
Accurate gauges are not really necessary for a good sync job.
The only requirement would be that all the gauges match.
The best way to test they are all equal would be to hook them all together with a common manifold and observe what each one reads.
In this situation, they should all read the same as each other, with very little discrepancy.
If the gauges are good ones, there should be an adjustment to allow you to zero them in.
mmurffy03
03 standard
« Reply #17 on: October 26, 2013, 09:20:36 AM »
bigbf I know and you know that the screws can be only out only one turn or less why do most books recommend the settings to be in the 1 3/4 to 2.5 turns out ?
