April 29, 2026, 07:56:16 PM *
Author Topic: Coolant smell while running  (Read 1672 times)
SideCar
Bikers don't need shrinks!
Colleyville, TX
« on: October 22, 2013, 02:03:06 PM »
Lately, I have smelled coolant while the engine is running.
-No watery substance in the oil.
-Doesn't seem to be a smell in the exhaust based on sniff test at the tailpipe.
-No visible leak.
Any ideas?
Daniel Meyer
Moderator
The State of confusion.
« Reply #1 on: October 22, 2013, 02:08:36 PM »
Make sure radiator cap is on completely...if it was removed without loosening the set screw it can mess up the sealing surface. Also check the integrity of the hose that goes to the reserve coolant tank.
It's also fairly common to need to tighten the clamps on both ends of the radiator hoses.
Then, look at the weephole in the water pump for signs of leakage there.
CUAgain,
Daniel Meyer
SideCar
Colleyville, TX
« Reply #2 on: October 22, 2013, 02:54:36 PM »
Thanks. Will check those things as well.
Flat6Valk
Blacklick, Ohio
« Reply #3 on: November 03, 2013, 07:45:15 AM »
WATER HOSE READY TO GIVE OUT.  THAT WAS MY EXPERIENCE.
5_19
Dublin, Texas
« Reply #4 on: November 04, 2013, 05:07:52 AM »
.........And on my bike, where the hose connects to the overflow tank, had a small crack in it that would only leak when the bike was warmed up. Some of the radiator fluid would drip on the hot exhaust. Off course that makes it easy to smell and fix.
IBA # 45723
2009 BMW R1200 GSA
SideCar
Colleyville, TX
« Reply #5 on: November 08, 2013, 06:57:58 AM »
Thanks for the ideas. If I get time in between Int'l Moto Show this weekend, I plan to look her over.  Until then, it's just ride and ignore the faint smell.
