February 07, 2026, 08:21:54 PM *
Author Topic: Vacuum line clips  (Read 996 times)
ugelstad
« on: October 23, 2013, 06:03:57 PM »
Does anyone know what size the spring clips are that hold the vacuum lines on?  6mm or 8mm or other.
« Reply #1 on: October 23, 2013, 07:38:12 PM »
I dont use them things
Thunderbolt
Worthington Springs FL.
« Reply #2 on: October 24, 2013, 04:16:37 AM »
I use 5/32 vacuum line and throw them away first time I get the aggravating things off.
Joe Hummer
Arnold, MO
« Reply #3 on: October 24, 2013, 05:42:27 AM »
I agree with Thunderbolt...I have gone to the 5/32 vacuum lines and can't put the clamps back on.  They just won't go over the outside of the tubing (thicker wall material than stock).  You can pick up the tubing in bulk at any auto parts store.
If you are running stock tubing and are aggravated at the stupid little spring clips...here is a vast improvement...
http://redeye.ecrater.com/p/14344948/7-mini-hose-clamps-for-valkyrie-happy
I also buy the vac caps and intake o-rings from these good folks.
Joe
1999 Valkyrie Interstate
Farther
Quimper Peninsula, WA
« Reply #4 on: October 24, 2013, 07:13:05 AM »
+1 on Red Eye Tech stuff.
~Farther
Brian
Monroe, NC
« Reply #5 on: October 24, 2013, 07:10:26 PM »
I don't recommend red eye tubing. It is really thin and tears easily. Auto store tubing works better for me. I am using the OEM clamps and a few of the red eye clamps. I have yet to run without the small clamps on these.
