February 07, 2026, 10:14:21 PM
Storage tank under A/F
Topic: Storage tank under A/F (Read 1084 times)
TJ
Lake Placid , Fl.
October 29, 2013, 02:38:45 PM »
Did a de-smog on a valk and can't remember if I can cap this off.... Any help... # 10 in pic....
Denny47
#34898
Grove, Ok.
Re: Storage tank under A/F
October 29, 2013, 05:31:45 PM »
Can't remember on that hose in particular but you only plug one of the outlets on the belly of the air box. I believe the one you plug is where the hose goes to the pair valve.
1997 Green/Cream Tourer w/ Cobra 6/6 exhaust, 2012 Pearl White Goldwing
USAF 66-70, F-105 AWCS
PAVALKER
Pittsburgh, Pa
October 29, 2013, 05:59:40 PM »
Just did it myself.... the only one I capped off on the airbox itself was the one forward, the two rear ones remain connected to the box. Some say to use a bolt and washer, I just used a large vac cap.
And I will say... it does seem to run and sound better. Could be that I had some minor vac leaks or one of the boots wasn't on all the way, but it is all working good so far.... had it out for a 160 miles run today.
John
October 30, 2013, 07:33:36 AM »
That's part of the crankcase breather system and should not be disturbed nor capped off.
TJ
Lake Placid , Fl.
October 30, 2013, 08:10:33 AM »
It's just an oil collection tank in case you have some blow by... It doesn't connect to anything
buy the air filter box and a drain tube...
PAVALKER
Pittsburgh, Pa
October 30, 2013, 08:21:24 AM »
John
Denny47
#34898
Grove, Ok.
Reply #6 on:
October 30, 2013, 11:02:19 AM »
Quote from: TJ on October 30, 2013, 08:10:33 AM
And if you plug off the crankcase ventilation, you will blow oil out your a** , er, exhaust.
