February 07, 2026, 10:14:23 PM *
Author Topic: IS Grab Rail Bolts  (Read 1179 times)
SpidyJ
Murrells Inlet
« on: October 30, 2013, 10:25:26 AM »
Dang if I can find a listing on any parts site.
I need the large bolts that go through the grab rails into the nuts in the nutcage inside the rear fender.
Anybody got a link?
If not I'll figger out the size X length somehow.........just lazy.  Somebody here prolly has it memorized!
Thx
jpw
1999 Fast Black Interstate
Peace,
johnnywebb
Michvalk
Remus, Mi
« Reply #1 on: October 30, 2013, 11:42:59 AM »
Honda didn't make grab rails for the Valk, so that's why you can't find bolts for them. The only grab rails I am aware of were made by Rivco, and they don't make them anymore. You will have to find the fender rail bolts and buy them slightly longer to fit the rails cooldude
« Reply #2 on: October 30, 2013, 02:09:06 PM »
What you want is the forward fender strut bots.  They will be in any valk schematic for rear fender.  Probably either 6 or 8mm.... something length.
If you do have Rivco grab rails.... the bolts are likely longer than original.  Ask Rivco.
SpidyJ
Murrells Inlet
« Reply #3 on: October 30, 2013, 02:44:15 PM »
I have a stock 99 IS and the Honda schematic does call them grab rails but doesn't show the long bolts that go thought the chrome rails thru to the nut cages.
Peace,
johnnywebb
Tailgate Tommy
Fort Collins, Colorado
« Reply #4 on: October 30, 2013, 03:11:31 PM »
If you have these grab bars, it looks like they use the stock fasteners. (for the std)
INSTALLATION INSTRUCTIONS
LEFT & RIGHT GRAB HANDLE FOR VALKYRIE
#VAL009LR
RIVCO Products, Inc. 440 South Pine Street Burlington, WI 53105
(262) 763-8222 www.rivcoproducts.com
STANDARD & TOURER INSTRUCTIONS
1. Remove the seat.
2. Remove the upper shock bolt
3. Remove the lower backrest bolt.
4. Install the grab rail loosely using the original bolts
5. Tighten securely.
6. Re-install the seat
INTERSTATE INSTRUCTIONS
1. Remove the seat.
2. Remove the upper shock bolt.
3. Put the front end of the grab handle (slotted end) centered on the shock bolt, snug the bolt.
4. Raise the rear hole of the handle to the highest position on the flat, before bend of the trunk
support bracket.
5. Mark and drill a ¼” hole.
6. Using the screw and nut provided, attach the rear of the grab handle. Tighten securely.
7. Tighten the shock bolt.
8. Re-install the seat.
« Last Edit: October 30, 2013, 03:13:32 PM by tkylli » Logged
mmurffy03
03 standard
toms river new jersey
« Reply #5 on: October 30, 2013, 03:51:54 PM »
You mean the bolts that hold the leather OEM bag support brackets in place the front ones are a bigger diameter than the rear ones and the rear ones have those square nutcages that move around and can slide out of there holders rite ?
wiggydotcom
Yorkville, Illinois
« Reply #6 on: October 30, 2013, 03:58:40 PM »
Anybody got a link?
Thx
jpw
If you are meaning the bigger bolts that hold the saddlebag brackets to the fender, the bigger one is an M10x1.25 which is FINE thread (for an M10). The smaller one is an m8..don't remember if it's fine or coarse thread.
VRCC #10177
VRCCDS #239
« Reply #7 on: October 30, 2013, 05:24:15 PM »
The 2 bolt sizes are 10mm X 1.25 pitch and 8mm X 1.25 pitch.
SpidyJ
Murrells Inlet
« Reply #8 on: October 30, 2013, 05:37:45 PM »
Thanks folks......just need the length now.
jpw
Peace,
johnnywebb
SpidyJ
Murrells Inlet
« Reply #9 on: October 31, 2013, 09:48:18 AM »
I found the bolts. They are shown on the Saddlebag drawing for the IS, not the Rear Fender drawing.
They are #43  and #45 on the exploded dwg.
kpw
Peace,
johnnywebb
