February 07, 2026, 11:42:32 PM *
Author Topic: 6 into 2 exhaust system question  (Read 3491 times)
98pacecar
« on: November 06, 2013, 07:29:57 AM »
Hi, new here, Don't even have the bike home yet. Anyway, My 98 has pipes on it that extend maybe 4 or 5 inches (just guessing by looking at some pics) beyond the beetle bags n' rear fender.  The open ends are round and straight cut, no angle.   What I would like to know is,,, are they most likely, after market mufflers, or has the outside chrome skin only,,,, been replaced.
I'd post a pic, but don't see how to do that on this board.
Thanks, in advance,,,,, Jim
Michvalk
Remus, Mi
« Reply #1 on: November 06, 2013, 08:17:24 AM »
Just a guess, but, sounds like the "truck stack mod" which is just skins cooldude
« Reply #2 on: November 06, 2013, 09:35:22 AM »
Ask the previous owner (P O) what mods were done how long ago was serviced how old are the tires and visit the tech board.  cooldude And B T W-welcome to our little corner of the insanity.  2funny You have a LOT of knowledge here on these Valkyries we seem to be addicted to.  Wink Again-welcome from the Ozarks and RIDE SAFE.
reclaimerroger
« Reply #3 on: November 06, 2013, 10:49:43 AM »
It's not a truck stack mod if it has six pipes. cooldude Oops misread six into two.  If it is quiet probably just truck stack mod as said.
« Last Edit: November 06, 2013, 10:52:23 AM by reclaimerroger » Logged
98pacecar
« Reply #4 on: November 06, 2013, 10:52:58 AM »
Well I did ask him,,, n' since he ain't the man that built the bike,  he's clueless. Says he bought it for the new wiffy so they could do something together, n' she's scared of it, hence the sale. Soooo, no help there, n' why,,,,, I'm askin here.....
Can a pic be posted here?  Cause it IS worth 1K words...
« Last Edit: November 06, 2013, 01:21:16 PM by 98pacecar » Logged
Freep
Bayfield, CO
« Reply #5 on: November 06, 2013, 11:04:57 AM »
When you post a reply, up above the comment box are two lines of white squares.
The first box on the left is the "insert photo" box.
If you click on it you'll see two sets of brackets. In the left bracket it will say IMG in the right /IMG. The cursor will be blinking in between them. It's waiting for you to post the URL of an image.
In order to get the url of an image go to either Imgur or Photobucket, load the image you want, then read their instructions on how to copy images--in photobucket you click on the picture, when it comes up big, click on the button to the right that says, "direct." It will go yellow and say "copied."
Then come back to the forum, make sure your cursor is still between the 'img' brackets and hit ctrl-v.
Viola! Pick in the message.
Simple, no?  cooldude
And welcome.  Smiley
Freep
Keep thine eye upon thine tach and thine ears upon thine engine lest thy whirlybits seek communion with the sun. John 4:50
98pacecar
« Reply #6 on: November 06, 2013, 11:09:56 AM »
Managed to post them below.
« Last Edit: November 06, 2013, 11:33:38 AM by 98pacecar » Logged
9Ball
« Reply #7 on: November 06, 2013, 11:15:38 AM »
nice truck stacks....
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
98pacecar
« Reply #8 on: November 06, 2013, 11:26:31 AM »
Ok now dat we know WHAT they are...
 Can you splain, to me,,,,,,,,,,,,,,, WHAT they ARE????
Does that mean they are stock mufflers (probably partially gutted) with a new outer wrap???
98pacecar
« Reply #9 on: November 06, 2013, 11:29:07 AM »
test
98pacecar
« Reply #10 on: November 06, 2013, 11:30:28 AM »
98pacecar
« Reply #11 on: November 06, 2013, 11:32:56 AM »
Wow thanks,,,, as a computer illiterate, I'm grateful for the lesson....
« Reply #12 on: November 06, 2013, 12:19:56 PM »
Nice Bike cooldude
Truck Stacks added to the OEM pipes.  You'll have to look down them to see if the "Piggies" are still there, but most likely they've been cut down or out.
Do a search for "exhuast" or "pipes" or "piggies" here and you'll get three thousand responses that you can scroll through to get an idea of what stock is.
Again, nice ride.
« Reply #13 on: November 06, 2013, 12:27:35 PM »
I'm not seeing a seam down there, so they are probably full length stacks (from the collector).
« Reply #14 on: November 06, 2013, 12:54:52 PM »
I'll put my $$$$ on the nag in the 5th.
Glass packs.
« Reply #15 on: November 06, 2013, 04:03:02 PM »
What Jess said.  I'm not seeing a seam either, they look like stacks to me.
Stacks are a 4" chrome exhaust can that is slipped over the stock exhaust.  They are also used as the outter chrome can covering an exhaust that has had a glass pack modification done to them.
These are stacks and where alot of folks get theirs......
http://www.airflo.com/valkyrie.html
http://store.airflo.com/chrome-exhaust.html
Here's a couple links that have some drawings that show what the inside of a stock/OEM exhaust looks like.
http://luiscajiga.com/Exhaustm.htm
The short version is, if you look down into the end of your exhaust and see something else, there are two possibilies.....either they've been gutted, or they've had a glass pack mod done to them.
They could also be from another aftermarket Valkyrie exhaust manufacture.  Here's a list.  Some are still doing business, some not.
http://www.valkyrienorway.com/Exhaust.html
Shop Talk is a link at the top of the page here.  There's tons of info in there about virtually everything, including truck stack installation and glass pack mods.
http://www.valkyrieriders.com/shoptalk/
http://www.valkyrieriders.com/shoptalk/noteasy.htm
http://www.valkyrieriders.com/shoptalk/truckstackinstall.htm
If you want to finish off those stack with some nice tips, you can't go wrong with some Grumpys tips.   cooldude
http://www.grumpyscustomparts.com/product-pictures--store-link.html
« Last Edit: November 06, 2013, 04:07:05 PM by BF » Logged
Thunderbolt
Worthington Springs FL.
« Reply #16 on: November 06, 2013, 05:58:18 PM »
They look like truck stacks.  Look from the rear for a plate with 3 holes or short pipes.  If you see them someone probably just added the truck stacks to the oem pipes.  If you only see one hole or pipe in the center they could be glass packs.  Sent you a PM about the Florida board.
« Reply #17 on: November 06, 2013, 06:06:02 PM »
If you have muffler clamps visible underneath, or a crossover flex tube, you have a MarkT exhaust.  Be glad, they sound great, make more power, and are worth hundreds more than stock pipes.
ricoman
Sarasota, FL
« Reply #18 on: November 07, 2013, 04:53:59 AM »
well said, Mark
and you should know!
98pacecar
« Reply #19 on: November 07, 2013, 05:25:23 AM »
Ok thanks all...
 Now I know what to look for, once I actually get the bike,,,, home.
Jim
« Reply #20 on: November 07, 2013, 10:37:23 AM »
Jeff K had contacted someone and if he could get orders for XXX number of pipes, they would reproduce another batch.
« Reply #21 on: November 07, 2013, 02:44:30 PM »
Mase.....
I remember someone posting about a set of pipes like that once before.  Don't know if your thinking about the same set of pipes, but he said that they were Cobras with some tips on them that he had made to fit.
« Reply #22 on: November 07, 2013, 04:55:58 PM »
HotGlue cut the ends off a set of 2-Brothers 6 into 6 and added some extensions that end past the rear of his HUGE Boss bags.
Hay Cool
Bugslayer
Lubbock, Texas
« Reply #23 on: November 10, 2013, 07:50:26 PM »
Hay Cool
I'd like to see that. I have a set of TBR's in the shed that I put on every couple years. Just wish they were longer.
« Reply #24 on: November 10, 2013, 08:55:43 PM »
Talk to Mark, ask him if he would weld them up if you brought the material.   All he can say is NO, if he does, then it isn't too good of an idea.      You will probably have to grind them down and have them chromed, if he does the welding for you.
In 98 or 99 I put 6X6 on MGM, rode it for a few months and went out to the Truckstop that had a basement full of Truck Chrome.
I forgot the length of pipe I bought, but we slid them over the 6X6, with some notches, the pipe was about 4" longer, and it had a hell of a bark to it.
Bugslayer
Lubbock, Texas
« Reply #25 on: November 13, 2013, 12:16:47 PM »
I'd like to cut off  the "turn-outs", and add longer pipes.  But right now, my cash flow isn't that great. It's flowin out faster than it's flowin in.   tickedoff
Lately, I've had the urge to put the TBR's back on.... and this thread has pushed me over the edge. As soon as my exhaust gaskets come in, I'll be switching over.   cooldude
Bugslayer
Lubbock, Texas
« Reply #26 on: November 13, 2013, 12:19:19 PM »
dragon_slayer_129
Throttle Jockey
Leipsic, OH
« Reply #27 on: November 22, 2013, 05:28:23 PM »
Nice valk  cooldude cooldude
I second getting a set of grumpy's tips or trim rings to really dress up the ends of your truck stacks.  I really like the trim rings I bought for mine last year.
Your stacks will go from this:
To this:
A nice close up:
Dragon Slayer 129
'01 Interstate - Fast Black w/loads of chrome - 63K miles
'95 CBR 600F3 - 67K miles
'14 Bennington GSR2250 Tri-toon 150HP Yamaha
To many toys not enough time to play !
[img width=347 height=175]http://i371.photobucket.com/albums/oo160/Rashed_F3/vtx%20forums/VisitedStatesMap.jpg[/img
98pacecar
« Reply #28 on: November 24, 2013, 07:22:11 AM »
Nice.. How, do they attach?  Set screw on the bottom errrr what?
dragon_slayer_129
Throttle Jockey
Leipsic, OH
« Reply #29 on: November 25, 2013, 04:47:48 PM »
If you look real close at the tight shot of the trim rings you can see one of the allen head set screws (3 total) that hold the trim ring in there.  Look in about the 4 o' clock position and you'll notice it.  I've had them installed for almost 2 years now and no problems of them ever coming loose.
98pacecar
« Reply #30 on: November 26, 2013, 06:01:46 AM »
Got it,,,,,,,, thanks...
When I get the bike home (friday)
I can start breaking the bank with more add ons....   cooldude
