Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: November 07, 2013, 04:37:19 PM » |
It appears to be antifreeze dripping on the kickstand side near the cylinder toward the front. Kind of looks like maybe it starts from under the timing belt cover in the same side. It has done this for several years but only when the temperature gets close to freezing. No issues in the summer or when it is below freezing. It will take days for a quarter size spot to form. Any thoughts?
 ************************************************************** Dropbox is a neat app I found that I use to store files and pictures of my Valk. **
« Reply #1 on: November 07, 2013, 04:41:37 PM » |
Fairly common occurrence. Believe that is a radiator hose. It's always at seasonal cold temp changes.
Live with it, or get in there and tighten the clamp.... squeeze the hose and see if it is mushy somewhere, if so replace it.
Bone
« Reply #2 on: November 07, 2013, 04:54:40 PM » |
Maybe it's our location. I'm in S. Michigan my 98 Tourer did the same for 2 years. Tightened up what hose clamps I could see and the drip hasn't returned. Jess has the answer.
« Reply #3 on: November 07, 2013, 05:03:40 PM » |
First time it gets into the 20s here it are time to tighten the hose clamps-again.  RIDE SAFE.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #4 on: November 07, 2013, 05:18:36 PM » |
I kind of figured it was something like that and wasn't too worried. I'll see if I can tighten it.
« Reply #5 on: November 08, 2013, 05:11:07 AM » |
What you describe is exactly like what mine did when it was the upper hose that goes to the thermostat housing. Heres what you do. First, verify the thermostat housing is wet (indicating the leak) by shining a flashlight at it from the left side of the bike just forward of the carburetors. if the thermo housing is dry well, this may not be your problem....if its shiny, its wet and heres what you do next. Remove the one bolt securing the radiator (its at the top in the center) tip the radiator forward just enough to gain access with a flex drive extension and (i believe) 8mm socket.....tighten her up and it should be good to go
« Reply #6 on: November 08, 2013, 07:31:31 AM » |
Mine has also done this. Both times i noticed it was at smokin joes fall color ride the last 2 years. I'll add this fix to the list of things to do this winter. Mine actually drips off the timing belt cover on kickstand side.
« Reply #7 on: November 08, 2013, 07:47:10 AM » |
Of course, the bike sits on the sidestand and the liquid follows gravity.
F6Dave
« Reply #8 on: November 08, 2013, 09:04:51 AM » |
My Interstate does it much worse than my Tourer. Sometimes I tighten the clamp, other times i just live with it as it happens only at startup in cold weather.
If you decide to ignore it, just make sure you check the level of the coolant overflow tank more often than you would otherwise.
« Reply #9 on: November 08, 2013, 09:26:18 AM » |
ahhh, that's how it works.  i was sure it would drip off the high side.
SpidyJ
« Reply #10 on: November 08, 2013, 09:38:10 AM » |
ahhh, that's how it works.  i was sure it would drip off the high side.  [/quote] Haw! I just noticed the same drip on my garage floor last weekend. First time since I've had the bike, 37 degrees one morning must have done it.
1999 Fast Black Interstate
Peace, johnnywebb
Romeo
J.A.B.O.A.
Romeo, Michigan
« Reply #11 on: November 10, 2013, 01:43:20 PM » |
Mine is doing it as we speak, uh type. Anyway, its on the list .
