May 09, 2026, 01:59:52 AM *
Author Topic: What have I got myself into.  (Read 5836 times)
BigMac (SoCal)
Moreno Valley, California
« on: November 16, 2013, 03:27:16 PM »
All is going well, got her desmoged and the trailer cleaned up. Next I go through the carbs.
« Reply #1 on: November 16, 2013, 03:50:27 PM »
Damn you've been a busy young man cooldude
BigMac (SoCal)
« Reply #2 on: November 17, 2013, 08:26:41 AM »
Well I ordered the Dan-Mark fuel shut off valve so the next owner will never have hydrolock problems. Should have the carbs back in Monday or Tuesday. Then I start going from front to back going over everything and changing all fluids. I will also remove the rear wheel and check the final drive and shaft.
Someone is going to get a nice bike!
« Reply #3 on: November 17, 2013, 11:33:57 AM »
Hey Dave, did you use the red eye shiney desmog kit or do it with freeze plugs? And which Dan-Marc did you use, the one with the filter or without? Rob
BigMac (SoCal)
« Reply #4 on: November 17, 2013, 04:45:03 PM »
I use the freeze plug method, it's alot cheaper and works for me well. I use the Dan-Marc without the filter and put a filter in line with it. Still waiting for delivery for mine.
http://www.dan-marcrvparts.com/12vomufushof.html
The filter I use is a Wix no. 33049 and replace the T in the fuel line with a brass one and replace all clamps with the screw type.
Got the carbs back in the bike today and have to do a few more things before starting her. I also had to replace one  of the throttle cables and a slow jet that was broken by someone.
Prescott John
Prescott, Az.
« Reply #5 on: November 18, 2013, 10:37:42 AM »
I see a test ride in the near future.  Where are we going on the next ride Dave, Death Valley?  Looks like a nice bike for someone.
