February 07, 2026, 11:40:44 PM *
Author Topic: Rear speakers for 99 I/S  (Read 1231 times)
kimed123456
Brooksville, FL.
« on: November 17, 2013, 08:26:58 PM »
What speakers has anyone used in the trunk ? Easy install ?
PhredValk
Edmonton, Alberta, Canada
« Reply #1 on: November 17, 2013, 09:39:37 PM »
I used the Polk Audio DB501s. In fact I put the 501s in the faring pods as well. They are 4.5" marine speakers. See
http://s161.photobucket.com/user/wixthedog/library/Front%20Speaker%20Upgrade?sort=4&page=1
for front pods and
http://s161.photobucket.com/user/wixthedog/library/Rear%20Speaker%20Upgrade?sort=4&page=1
for rear speaker mod.
Also, Electrical Connections sells a rear speaker harness
http://www.electricalconnection.com/wire-harnesses/hrns_speaker.htm
With just the fronts, and no amp, there was a marked improvement in sound. I haven't got the rears hooked up (the harness doesn't seem to be long enough, but I will play with it over the winter), and I have a marine 4-way amp I will install as well. I expect wonderful things...
Fred.
VRCCDS0237
BigBad1
1999 Interstate
Garner NC
« Reply #2 on: November 17, 2013, 09:46:49 PM »
I have Polk DXi 400. They are exact fit but you will need to change the ends of the speaker wire (Polk connectors are smaller). I can't comment on the sound because I do not have them connected yet. FYI they are 4 ohm's and the front speakers are 2 ohm's. They means that they will need more power (amps) to get the same volume. I have an amp to install before I connect the speakers. I would really like to find a set to replace the front ones before installing the amp. The amp is probably not a necessity but I think it will help with the 4 ohm speakers.
fordmano
San Jose, CA.
« Reply #3 on: November 17, 2013, 11:42:38 PM »
The DB501's from Polk audio will fit fine in the front you will need to do some custom work on the old speakers to help make the new one a perfect fit. Follow the links listed above and/or do a search for Multipoint that's my old thread that I have a few alternate pictures from my install.
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
kimed123456
Brooksville, FL.
« Reply #4 on: November 18, 2013, 10:20:03 AM »
Thank you for your help. Ed
SloRider
« Reply #5 on: November 18, 2013, 01:37:35 PM »
I used the Honda speakers. That was 10 years ago so I don't remember specifics. I do know it was a very simple plug and play. If I did it anyone can. The quality has been ok but they don't seem to be as clear as the fronts and they are in need of replacement. That being said - I listen to speed/thrash/death metal so I have put them through plenty of abuse.
Gunner
NW Suburbs Mpls, Minnesota
« Reply #6 on: November 18, 2013, 04:51:06 PM »
I put these J&M speakers in the rear of my 99 IS.  They are a direct replacement and the terminal spades even match the Honda wiring.  It was easy to take the old rear speakers out and replace them with these J&M's.
http://www.sierra-mc.com/proddetail.asp?prod=JM-USK-9000
« Last Edit: November 18, 2013, 04:53:46 PM by Gunner » Logged
BradValk48237
Oak Park, MI
« Reply #7 on: November 18, 2013, 05:17:22 PM »
Polks here...
Ditto on follow the mods listed... easy hour or so to do.... just need dremel for the backs....
Brad
kimed123456
Brooksville, FL.
« Reply #8 on: November 18, 2013, 06:43:39 PM »
My 99 I/S didn't come with rear speakers, so the installation is from scratch. I just don't want to screw up and connect to the wrong wires.
bikerboy1951
Grand Forks, ND
« Reply #9 on: November 18, 2013, 07:59:05 PM »
Buy the wire already made up from Electrical Connection.  I have the original installation instructions if you want them.
Brad
« Last Edit: November 19, 2013, 12:53:54 PM by bikerboy1951 » Logged
kimed123456
Brooksville, FL.
« Reply #10 on: November 19, 2013, 11:19:33 AM »
Thank you, yes, if you could copy the instructions and post them up or email them to me that would be a big help. I'm less than mechanically inclined so you can imagine the importance of pictures and instructions.
