April 29, 2026, 08:17:18 AM *
Author Topic: HEY Bigum!!!!!!!!  (Read 3998 times)
« on: November 18, 2013, 10:09:11 AM »
Why are you pulling the engine for a 2nd time?
Bigun
VRCC# 32964
Monroe, Iowa
« Reply #1 on: December 27, 2013, 09:56:51 PM »
Dont Ask tickedoff Carbs screwed the pooch again. Damage isnt as extensive and I have the parts just need the time to tear into her again. Going to get the carbs completely rebuilt this time for peace of mind so it never happens again.
1999 Valkyrie Interstate
« Reply #2 on: December 27, 2013, 10:18:36 PM »
WOW MOM, blonde doing cart wheels.
You have had a bitch of a time with that ride.
Good Luck.
Ya might consicer a Pingle valve and a Dan Marc electric shutoff.
I can't believe that ride did a back flip on ya.
That day I saw it at the dealership in Indianola, it sounded like a sweet running ride.
I think he had just called ya to tell ya it was done.
« Last Edit: December 27, 2013, 10:21:10 PM by R J » Logged
Bigun
VRCC# 32964
Monroe, Iowa
« Reply #3 on: December 28, 2013, 11:54:09 PM »
Yeah I was heart broken. Already have the pingel rode it home from work, shut her down and was going to get changed and take the ole lady for a ride got on hit the starter and crunch. Forgot to turn the pingel off. tickedoff Definately need the Danmark. She was running sooooooo goood makes me mad just thinking about it.
« Reply #4 on: December 29, 2013, 10:42:48 PM »
You are going to be an expert on these Hydolock repairs if ya keep this up.
Hope ya have better luck in 2014.
PS:   Get that DanMarc valve as soon as possible.   AND INSTALL IT.
Mine works slicker than Sn** on a glass door knob.   I have gotten in the habit of turning the Pingle to off about a 1/2 mile from home and it will die as it is rolling down the driveway.    I try to start it a couple of times, no start, no pop, I back it into it's big bed and turn the key off.    Also turn off the extra switch when he is to be parked for a few days, month or 3 months.
I'm assuming you have the non vacuum Pingel, that flows any time a float says I need gas.   That is what I have.
PPS:    Make sure you keep the gas line from tank to carb bank on a slight downhill route all the way.    I've seen a couple of people that had their Dan Marc tipped the wrong way.   Exit spout above the input.   As long as ya got lots of gas in the tank it will work great, get it down to like a 1/4 tank, it starts suffering a fuel loss with the exit spout higher.   1/4 tank the weight of the fuel in the tank is not enough to push the required amount of fuel to the fuel bank..
Good Luck Bro in 2014.   You have had enough trouble for one year.
