February 07, 2026, 11:40:43 PM *
Author Topic: Sluggish on start  (Read 1303 times)
RicksF6
Rio Rancho New Mexico
« on: November 19, 2013, 03:31:28 PM »
My 1998 Valkyrie is sluggish on the start, almost bogging for a few seconds and then takes off, the idle is set at 800-900RPM. once your on the road it runs fine just stopping and going? any ideas on whats wrong.
« Reply #1 on: November 19, 2013, 03:38:16 PM »
Sounds like dirty low speed jets, add a mega dose of techron or seafoam and go for 30 min low speed rides park the bike and let if sit for a few hours or over night between rides, but keep the techron/seafoam added to the fuel until it cleans up.
Has this just started after prolonged period of not riding?
RicksF6
« Reply #2 on: November 20, 2013, 10:08:08 AM »
Yes it was parked for 3 months or so when i bought it, I'm a new Valkyrie rider (sold my Goldwing) I ran some carb and jet cleaner thru, but didnt have any affect, will try the seafoam I hear it works great...Thanks
« Reply #3 on: November 20, 2013, 12:31:00 PM »
What kind of petcock and does it have an in-line fuel filter ?
RicksF6
« Reply #4 on: November 20, 2013, 01:15:31 PM »
 I'm not sure what you mean about petcock, and it does not have a fuel filter. (but it is on my to do list) for this winter.
« Reply #5 on: November 20, 2013, 01:39:40 PM »
That is the barely minimum recommended, actually 800 rpm is too low.
You would have a more responsive motor with the idle set @ 1000 rpm.
« Reply #6 on: November 20, 2013, 01:40:59 PM »
If once the engine has been run a bit and the sluggishness goes away, and, if the engine runs smoothly and accelerates smoothly from just off idle to 2500rpms [low circuit] and beyond [high circuit], then it seems like it just may be slow to first deliver fuel upon start-up. That could be a petcock [fuel valve] or fuel filter issue. What kind of petcock do you have ? Vacuum or manual ? If vacuum, check the vacuum supply line/hose [ on #6 cyl] and if good then the petcock may need repair.
I would also recommend continuing using some Sea-foam for a couple tanks.
« Last Edit: November 20, 2013, 01:42:35 PM by Patrick » Logged
RicksF6
« Reply #7 on: November 20, 2013, 02:00:33 PM »
ok will try these ideas, Thanks
Rio Wil
« Reply #8 on: November 21, 2013, 03:54:46 PM »
Is your avatar a photo of your bike, if so, post a bigger one so we can see details......looks like a great Valk!
RicksF6
« Reply #9 on: November 22, 2013, 11:02:21 AM »
No thats not mine, I wish Sad Got the pic. on line type in "Valkyrie Motorcycle Pictures" this one is so cool!
