sugerbear
« on: July 18, 2009, 07:52:14 PM » |
is it unheard of for the tension pullys on the timing belt to be bad at 37,000 miles 2k I/S? what kinda of sound do they make? mine sounds like a very high pitched "warble", directly related to engine speed, and loud enough for ME to hear.
also as a side note: i have a coolant leak, replaced the radiator cap, still leaks. come up over the right side as i'm running down the highway. not much just a few drops. could it be coming from the upper rad hose?
thanks
Redeye
Shameless Pusher for "Red Eye Tech Services"
Overland Park, Kansas
« Reply #1 on: December 20, 2011, 12:11:52 PM » |
It sounds like you have a leak where the "top hose" attaches to the ratiator. A good cheap way to find leaks is to stuff toilet paper into various nooks and crannies, and take a drive. The leak will wet the TP.
You can listen to the tensioner pully bearings with a piece of tubing or a stick, one end on the questionable part and the other end on your ear. They also make mechanics stethoscopes for this. These bearings can indeed go out when still young, if they did not get lubed right at the factory.
Rich
« Last Edit: December 20, 2011, 12:35:08 PM by Redeye »
Cheers, Rich
1999 Valkyrie Interstate Mods: ECT timing mod with clutch switch mod, drilled baffles, gel pads in the seats, taller windscreen, longer kickstand, Metzler ME880 front, Dunlop OEM back.
« Reply #2 on: December 20, 2011, 03:11:02 PM » |
They also squeal if too tight, you haven't possibly been messing with them recently have you?
Jeff K
« Reply #3 on: December 20, 2011, 03:12:40 PM » |
The belts can "sing" if they are too tight or too loose. I have heard of pulleys going bad but only one time.
art
Grants Pass,Or
Grants Pass,Or
« Reply #4 on: December 20, 2011, 03:23:42 PM » |
Bearings can go bad early.Take the belts off an check them or listen when the engine is running [ be careful of injury].The bearings can more than likely be replaced,after all it is only a tensioner pully
« Reply #5 on: December 20, 2011, 03:26:18 PM » |
+1 JeffK.
Trust me, I know these belts will sing.
I used to put timing belts on those dang little Ford Escorts. Son hated them so I did them to help him out. My 1st one sang like a scalded Hawk would. I also got to where I could do them in less time than the labor book allowed.
Jeff K
« Reply #6 on: December 20, 2011, 03:30:41 PM » |
The bearings are not replaceable.
art
Grants Pass,Or
Grants Pass,Or
« Reply #7 on: December 20, 2011, 03:34:40 PM » |
just a thought .I haven't tried.Be cheaper than replacing the pully i would think.
sugerbear
« Reply #8 on: December 20, 2011, 03:35:50 PM » |
????????????????????????????????????????????? july of 09??????????? how did THAT pop up??
