February 07, 2026, 11:41:21 PM *
Author Topic: Just got off my first real ride of a Valk, and,,,,  (Read 2741 times)
98pacecar
« on: November 25, 2013, 12:55:49 PM »
 I have a question .
I noticed a ringing like noise when rolled on in 5th gear from 45 ish mph.
Is this due to straight cut gears errrr what.
This bike has 6 into 6 pipes (with baffles) n' the noise drowned out the exhaust note...   Cheesy
I was riding without ear plugs, with an open face shield, to really listen,,,,, to the bikes sounds..
This is not,, my bike,,,, n' has 10K on it.
Just rode it to try n' see what to expect in a few days,,, when I pick up my bike...
Jim
Bone
« Reply #1 on: November 25, 2013, 01:44:30 PM »
This is listed in Shoptalk;
Known Valkyrie Problems
http://www.valkyrieriders.com/shoptalk/Known%20Valkyrie%20Problems.htm
98pacecar
« Reply #2 on: November 25, 2013, 01:49:28 PM »
Thanks, Bone..   cooldude
''#10  A Whining Noise Coming From the Engine.  This usually occurs between 45 MPH to about 55 MPH gradually going away as speed increases. This is common on the flat 6 engine due to the straight cut gears in the transmission. It is one of the things we have to endure to ride the best motorcycle in the world.''
Perfectly normal,,, as, I had,,,,,,,,,,,,,,, hoped... Cheesy
« Reply #3 on: November 25, 2013, 03:23:58 PM »
Make damn sure there are NO L E Os around when you try this. Somewhere in the 65-75 M P H range in 5th gear-take the throttle grip and try to twist it off!! And to those of us that have had these for awhile-the noises she makes let us know she is alive! Have the big chit eatin grins started with that short ride???????????  2funny They should have but if not they WILL!!  cooldude I've put a little over 49000 miles on mine since I've had it and she still makes me grin!!  Wink RIDE SAFE.
« Reply #4 on: November 25, 2013, 04:22:11 PM »
30 mph in second gear, go WFO, shift at 6200 rpm,keeping WFO, when you get to 100 mph, you will be shift to 5th gear as the mph crosses 100, if you redline in 5th, you will be in the vicinity of 125 mph.  That is the bet way I can accelerate fast.  Did I mention this happens quickly? Gotta be on your toes to not miss a shift, and Hang on tight.   cooldude  Did I mention this is a good way to race other bikes?  I never mastered taking off from a standing start, but I have the above down pat. I seldom red line in 5th gear, gettin to old for that.  cooldude Shocked  Hoser
BnB Tom
Where'd old times go?
Frisco, TX
« Reply #5 on: November 26, 2013, 05:42:22 AM »
1st gear.
   At a stand still.
     Clutch engaged.
        Both feet gently touching the ground.
            Rev engine to 6000 rpm.
              Hold on tight and pop the clutch.
                    YEOWWW!!    Evil  Evil
98pacecar
« Reply #6 on: November 26, 2013, 06:07:37 AM »
Yes,, fer a fat girl it's quick...    Shocked
But the reason I bought it was that,, n',,,,, comfort.
Ain't, a wiper snapper,,, no mo...   Embarrassed
Bear in mind, I also have a 175 RWHP ZX12R out in da garage.
N' we've seen a true (gps) 193 mph more n' once....
« Last Edit: November 26, 2013, 06:10:52 AM by 98pacecar » Logged
« Reply #7 on: November 26, 2013, 08:05:57 AM »
193 M P H SHOULD get the ole juices flowing!!  cooldude RIDE SAFE.
98pacecar
« Reply #8 on: November 26, 2013, 10:58:06 AM »
YES it did...     Shocked
Did that back in my early 50's  Wink
Kinda slowed,,,,,,, a bit of late.
But ya,,, the adrenalin rush, was,,, something... Cheesy
Bought the Valk to replace the ZX, gonna give it to my son...
Too old,,, n' fragile now, (hip replacement) for such foolishness....
Jim
« Last Edit: November 26, 2013, 11:37:57 AM by 98pacecar » Logged
« Reply #9 on: November 26, 2013, 11:23:21 AM »
I'll be 69 in Feb. 2014. I still like going fast-triple digits when in my mind anyway it appears safe. And yes I do realize someone may post a thread telling everyone here that I died in a high speed motorcycle crash. The one of many things bout me going out at anytime-some sumbitch that ain't worked for it gets what's left of my S S benefits!!  uglystupid2 As long as i'm able to throw a leg over and git her up offin the side stand i'll be ridin.  cooldude Course way da gubmint goin might could be outlawed in my time.  Cry I started at an early age on this high speed stuff and I still enjoy it.    coolsmiley I'm thinkin once you get used to the quirks of these fine machines you will be another convert. RIDE SAFE.
98pacecar
« Reply #10 on: November 26, 2013, 11:41:54 AM »
Speed junkies never, die we just,,,,, slow down...    Wink
Yer right, that's exactly why,,,, the valk...
1st n' 2nd are still impressive, n' it's comfortable to boot..  cooldude
Just found this link  Shocked
 1500cc supercharged Kawi in the works...
http://www.motorcyclistonline.com/newsandupdates/motorcycle_news/122_1111_kawasaki_zx_15_coming_soon/
Jim
« Last Edit: November 26, 2013, 12:31:07 PM by 98pacecar » Logged
Pappy!
Central Florida - Eustis
« Reply #11 on: November 26, 2013, 07:28:06 PM »
Also heard the 1700CC VMax is getting a supercharger as well....like it needs it !!!
art
Grants Pass,Or
Grants Pass,Or
« Reply #12 on: November 26, 2013, 09:16:39 PM »
You guys are all nuts and shouldn't be driving. I'm going to turn 71 come January and must confess that I'm nuts also. Seems like my Valk only wants to push the limits. I've had my 02 at 135 on the speedometer along side an 1800cc VTX.  What a blast.
8Track
Adelaide, South Australia
« Reply #13 on: November 26, 2013, 09:59:40 PM »
What does "pop the clutch" mean exactly?
WamegoRob
Wamego, KS
« Reply #14 on: November 26, 2013, 10:34:27 PM »
Release the clutch lever quickly, as opposed to slowly and smoothly like you normally do.
« Reply #15 on: November 26, 2013, 10:35:36 PM »
  Just EXACTLY what it sounds like. From a dead stop rev the engine 4G 5G no brakes and dump the clutch-engage the clutch. Make damn sure the machine is pointed straight AND level and be prepared for extremely quick adjustments as they become needed. And this type of abuse is EXTREMELY hard on all the components of the driveline and mayhaps-expensive!!  uglystupid2 RIDE SAFE.
98pacecar
« Reply #16 on: November 27, 2013, 06:11:39 AM »
Just curious,,,,,,,,,,,,, is it even possible to get the front wheel up in da air?????     Cheesy
« Reply #17 on: November 27, 2013, 07:51:59 AM »
   Short version-yes. WITHOUT dumping the clutch. The first time Daughter and I were rolling N. on a non divided 4 lane in the right lane when a brain dead S O B decided at the last moment he needed to make a left onto another highway and I was behind him.  Lips Sealed Loose gravel on the right so I waited fer brain dead and I was now back in 1st gear after the idiot FINALLY got hisself outin the way. Gentle roll on in first 20ish into second clutch fully engaged and I tried to twist the throttle off. As an old time moto cross guy I knew zackly what was happening when it happened-the front end came up-NOT a wheely but the front wheel was off the ground.  cooldude Somewhere on this board is a picture or a video of some one doing a wheely on a Valkyrie. And the first time the wheel came up on me I was already D/S. RIDE SAFE.
Bone
« Reply #18 on: November 27, 2013, 08:02:15 AM »
Upper left corner click Homepage: then click New Just Pics
All kinds of Valks including a wheelie or two.
« Reply #19 on: November 27, 2013, 11:07:26 AM »
I think I'd have more than juices flowing, probably have some solids flowing too! 125 mph is as fast as I'm comfortable going, and that's only for a few miles.
« Reply #20 on: November 27, 2013, 12:10:38 PM »
        On a good day for ME and making sure the machine is mechanically sound/safe/and as ready as it could be made-let's just DO IT.  cooldude Just like I used to tell the wimmenz-it's only kinky ONCE!!  2funny And the last time I checked us mere mortals could only die-ONCE!  2funny Got bit early on in life and NEVER quite got over it-i'm a speed-M P H-junkie.  coolsmiley RIDE SAFE.
98pacecar
« Reply #21 on: November 27, 2013, 12:21:31 PM »
 I used to do it about 2AM (no traffic or side streets or large birds) on the Skyway bridge.
I would be north bound, crest the bridge at about a buck forty errr so,  Just in case there was any serious cross winds.
Then tuck n' nail it, n' hold it nailed fer about 1 1/2 miles.
On one occasion as I crested the bridge, I saw 1 lone tail light way off in da distance.
Turns out it was a guy on a harley bagger, went by him at 193 (gps 218 speedo).
I think some of dat solid stuff you mentioned,,, may have eminated,, from him???
« Reply #22 on: November 27, 2013, 06:23:12 PM »
2funny 2funny
« Reply #23 on: November 28, 2013, 06:42:13 AM »
Just  curious-is the 193 M P H machine capable of 200 M P H?? RIDE SAFE.
98pacecar
« Reply #24 on: November 28, 2013, 07:19:26 AM »
Nope. back in da day I owned both a 00 ZX12 and  99 Hayabusa.
 At the time there was much ta do bout which one,,, was faster.
Both bikes maxed out at da same  193 mph,, on da same,, gps, on da same bridge.
 One speedo read 220, the other read 218..... I think,,,,,, da ''fix'' was in.    coolsmiley
« Reply #25 on: November 28, 2013, 07:50:37 AM »
NOT knowing that much about these VERY FAST machines i'm guessin here with todays technology maybe electronic chip limited. Back when I was building and racing my own stuff some sort of limiting factor might have helped my wallet some what.  2funny I've blown up a few engines with less than 1 ONE singular-1 hour on them.  Undecided Looking back though blowin up an engine or tranny(don't ask)was like a rite of passage.  cooldude RIODE SAFE.
98pacecar
« Reply #26 on: November 28, 2013, 08:50:23 AM »
zactly   cooldude
Tropic traveler
Silver Springs, Florida
« Reply #27 on: November 28, 2013, 07:30:46 PM »
'13 F6B red for Kim
whitestroke
San Pedro, Ca.
« Reply #28 on: November 28, 2013, 09:04:21 PM »
Alright now you sob's have made me want to go out and do max speed on my stock valk. How fast should max be?
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
« Reply #29 on: November 28, 2013, 10:54:03 PM »
    Two things only YOU can answer. How large are yer nards and how strong is yer heart?? O-K three things-do you REALLY want to go to W F O on the throttle in 5th gear?? From my own personal experience-it IS a rush!!  cooldude RIDE SAFE.
98pacecar
« Reply #30 on: November 29, 2013, 02:48:42 PM »
Pretty much,,,,, answers, dat huh??? 2funny
« Reply #31 on: November 29, 2013, 07:35:38 PM »
These machines are so nicely balanced they just mostly chit and git.  2funny AN UNDERSTANDING and SUPPORTIVE counter balance WILL help a LOT if you really wants ta git da front aireborn!!  Grin THAT pic of the red and white proves ma point perzackly.  cooldude Course iffin ya wants her P Od at ya the rest of yer life-don't tell her what ya'll are about to embark on-ya just KNOW how some gals LOVE surprises!!  uglystupid2 RIDE SAFE.
98pacecar
« Reply #32 on: November 30, 2013, 10:37:34 AM »
I'm really not,,, a wheelie, kinda guy..   coolsmiley
I wuz just,,,,,,,, wonderin...  Roll Eyes
I thought, being so heavy,,,, they might just light da tire n' go up in smoke, as opposed to pulling da wheel..   Cheesy
« Reply #33 on: December 03, 2013, 06:46:50 AM »
And the ATGATT of the second rider (Scott) is awesome!!!!....
But the sandals make the outfit...  Smiley
Hay  Cool
