February 07, 2026, 11:42:46 PM *
Author Topic: Cheap cosmetic fix  (Read 1546 times)
rikrok
« on: November 28, 2013, 10:03:47 AM »
The used Valkyrie I picked up had some signs of age. The lower front forks were pitted and the rear housing was also in pretty bad shape. About 5 minutes of actual labor ( dry time between coats not included), and a few cans of Plastic Dip later was all it took.
Before
After
Rick
Bradenton,FL
04 Honda Rune
13 F6B
99 Valkyrie
83 CB1100F
matt
Derry New Hampshire
« Reply #1 on: November 28, 2013, 10:12:15 AM »
looks nice  would like an update on how it holds up
9Ball
« Reply #2 on: November 28, 2013, 10:20:46 AM »
I like the plasti-dip color for the final drive...can you share the color or product number from the can?
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
rikrok
« Reply #3 on: November 28, 2013, 10:34:27 AM »
The wheels and rear cover are done with Anthracite Gray and coated with clear Glossifier. If you don't clear, it will have a matte finish.
Rick
Bradenton,FL
04 Honda Rune
13 F6B
99 Valkyrie
83 CB1100F
« Reply #4 on: November 28, 2013, 11:42:04 AM »
On my front fork lowers took a fine rotating wire brush on my H/F Dremel clone and cleaned it up. Then some 400 grit emery cloth and some aluminum polish and now it looks almost like chrome. You did a fine job with the paint. Again-let us know how long this lasts please. RIDE SAFE.
« Reply #5 on: November 29, 2013, 05:19:42 AM »
Where can one obtain this plastic dip you speak of?  Hoser  Wink
rikrok
« Reply #6 on: November 29, 2013, 05:24:46 AM »
dipyourcar.com.  I think there is even a 20% off sale today. I'm scanning the web looking for some kind of discount on Cobra pipes.
Rick
Bradenton,FL
04 Honda Rune
13 F6B
99 Valkyrie
83 CB1100F
« Reply #7 on: November 29, 2013, 05:53:04 PM »
Looks good rikrok! I removed the clearcoat from my forks using stripper them buffed them using Mothers Mag & Aluminum polish. I power buffed using a Mothers power ball. Worked great! Did my wheels too eventually.
« Last Edit: November 30, 2013, 04:58:53 AM by salty1 » Logged
My rides:
YoungPUP
Valparaiso, In
« Reply #8 on: November 29, 2013, 06:20:32 PM »
The nice point of plastidip is that if you change your mind later you can peel the plasti dip off and then do what you want.
99 STD (Under construction)
