February 07, 2026, 11:41:27 PM *
Author Topic: HELP!-Can't get airbox back on  (Read 2955 times)
snakemeister
Alabama
« on: December 04, 2013, 02:57:27 PM »
 After taking the airbox off I can't get the air tubes to sit back down on the air intakes. It's like they're about 1/4 inch  too short. I can't find anything holding the box up or preventing it from seating correctly. The bolt at the back of the box will line up if you press down on the airbox.Has anyone had any experience with this?
9Ball
« Reply #1 on: December 04, 2013, 03:09:08 PM »
to answer your question...we all have.
It takes patience and pressure to get it right.  Some use 2x4 and straps, others use twine and a second pair of hands.  Some of us even do it by ourselves.
Keep trying and make sure the tubes are properly slipped over the carbs...they tend to hang up in the back.  A mirror sometimes helps make sure the tubes are properly seated.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Daniel Meyer
The State of confusion.
« Reply #2 on: December 04, 2013, 03:15:42 PM »
There's a big black rubber hose that connects to a nipple on the bottom of the airbox...you got it on?
CUAgain,
Daniel Meyer
« Reply #3 on: December 04, 2013, 03:30:44 PM »
The fellas are right, it can be a royal PITA. It takes a lot of patience, and beer. Use a lot of well placed lighting and just keep after it. Those tubes like to hang up on the inside/backside of the carburetors. Just be careful, things bend easy. I just happen to not believe in using any aids like straps, etc., but, thats just my opinion.
98pacecar
« Reply #4 on: December 04, 2013, 03:56:10 PM »
Sounds a lot, like tryin ta get da rack of 6 carbs,,, back on a CBX..   tickedoff
Real, P I T A...
I used ta use a LOT,,, of WD40...    Could, help you also..  cooldude
Finally, used ta end up using a scissors jack against the frame rails, then a 2x4 between dat n' da carbs.
Spray rubbers liberally,, n' jack da bitches into the rubber collars...    Cheesy
Old story...     Roll Eyes    Hope,,,  the WD helps ya succeed,,, though.....
Patience,, is a virtue
I never,,, had....    Embarrassed
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #5 on: December 04, 2013, 04:02:56 PM »
From Shoptalk, hope it helps.
http://www.valkyrieriders.com/shoptalk/AirBox%20VentHose/AirBox.htm
« Reply #6 on: December 04, 2013, 04:28:16 PM »
I've tried them all and contrary to what friend Patrick says/does  Wink I use the strap method. First keep in mind those rubber intakes are flexible for a reason, you're not going to hurt them by bending them in. I do that to get the box generally in place but usually need to press it down to attach the tubes to the top of the carbs. That's when I put the top on the box, place a 4-6" piece of 2x4 on top and run a ratcheting strap over the top of the wood. Hook each end to the engine guard and ratchet it down snug. Now you have everything in place and can place the tubes where needed since you have both hands free. It's quick, easy, takes less #@$^&*, etc.  cooldude  I usually will have the box back in place in under five minutes, less time than it takes wrapping strings around the tubes.
Bugslayer
Lubbock, Texas
« Reply #7 on: December 04, 2013, 04:36:46 PM »
I picked up a little "dentist" mirror with a telescoping handle from Harbor Freight. I use it when I'm installing the air box. It helps to see the rubber boots that  get stuck on the lip of the carbs.  And for me, a helper is the best thing to hold down the air box.
« Reply #8 on: December 05, 2013, 04:10:51 AM »
Dag's video is helpful.
Airbox Install.mpgpowered by Aeva
My rides:
Bone
« Reply #9 on: December 05, 2013, 05:38:24 AM »
Thanks Salty for posting the video and thank you Dag for making the video.
I've removed the air box twice the second time was much easier. The next time
I will try some of Dag's methods I'm sure they will help.
signart
Crossville, Tennessee
« Reply #10 on: December 05, 2013, 12:35:34 PM »
The last couple times, I used the ziptie method and it worked great. Also, I attached the lid to the airbox before installation and that worked out for me.
snakemeister
Alabama
« Reply #11 on: December 06, 2013, 05:43:02 PM »
 I got it back on today by putting  the box together, putting a 2x4 on top and pulling it down with a
  tie down. It was easy after that.
« Reply #12 on: December 07, 2013, 06:01:38 AM »
Hey Patrick, did you see that?  nyaaa, nyaaa   2funny
So, are you coming down for the winter? Give a holler if so.
