February 07, 2026, 11:42:32 PM *
Author Topic: Front fuel tank bolt possibly stripped.  (Read 1174 times)
Cappy
Minnesota / Florida
« on: December 06, 2013, 01:50:21 PM »
Can someone tell me what the correct thread cutting size is for the front end fuel tank hex head bolt. Thanks Cry
Bone
« Reply #1 on: December 06, 2013, 02:13:14 PM »
HDL (Honda Direct Line) has this listing.  Is it a 6x25 bolt ?
   031   BOLT, FLANGE (6X25)
96001-06025-07   001   $2.50   $2.50
9Ball
« Reply #2 on: December 06, 2013, 03:08:35 PM »
I replaced the front factory bolt during the first time I pulled the tank in CY2000 to install my K&N air filter.  I bought a chrome hex head 1/4-20 bolt and drilled and tapped the frame.  I installed the bolt using red loctite up from underneath and created a "stud", then used a chrome washer and chrome acorn nut to hold the tank in place.  I forget the length since it was so long ago, but it was somewhere around 1-1/2" long.
The stud provides easy alignment when re-installing the tank and prevents it from sliding around during installation.  This was probably one of the best mods I have on the bike, of which there are many.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Cappy
Minnesota / Florida
« Reply #3 on: December 06, 2013, 03:24:33 PM »
The "stud" idea sounds great cooldude
But, I have a chrome plastic trim piece that I would like to retain. A chrome hex bolt takes a small cap to dress that up. I think I barely stripped the bolt threads, so I was hoping that I could easily tap that if I knew the exact cutting thread or tool number to to that. Maybe, I could use the bolt, if undamaged, and come from the bottom up. Roll Eyes
What do you think?
saddlesore
« Reply #4 on: December 06, 2013, 06:11:00 PM »
If you have a tap and die set check to see if there is a gauge in the set.  If you can match up the threads that way you can then match the correct tap.
DARE TO BE DIFFERENT
ricoman
Sarasota, FL
« Reply #5 on: December 07, 2013, 02:05:28 AM »
take the bolt you removed and match the threads against the die
9Ball
« Reply #6 on: December 07, 2013, 04:08:27 AM »
What do you think?
It will be too short....
1999 Standard
2007 Rocket 3
2005 VTX 1300S
