April 29, 2026, 06:33:37 PM *
Author Topic: Tranny Question  (Read 2691 times)
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« on: December 08, 2013, 05:55:40 PM »
Newbie doesn't own an Operator's Manual so I gotta ask.  I don't find any mention of changing the tranny lube, sooooo what's up with the tranny lubrication.  (Please no laughing at the newbie!)   Roll Eyes
'77 Gold Wing, '81 Gold Wing,
YoungPUP
Valparaiso, In
« Reply #1 on: December 08, 2013, 06:02:53 PM »
The transmission is lubricated with the engine oil in the crank case.   Some find that changing brands or from dino to synthetic quiets down the gear whine.
99 STD (Under construction)
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« Reply #2 on: December 08, 2013, 06:11:11 PM »
Thanks YoungPup.  Seems pretty noisey shifting but I "guess" that's normal.  Even my Beemer shifts/bangs going into the various gears.
YoungPUP
Valparaiso, In
« Reply #3 on: December 08, 2013, 07:36:10 PM »
They definitely have a whine to them.  That comes from the straight cut gears.
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« Reply #4 on: December 09, 2013, 04:19:23 AM »
I not heard any "whine" from the tranny just the noisy "clunk" when shifting.
Bert AKA,Valkaholic
Back-N-Black
« Reply #5 on: December 09, 2013, 05:03:17 AM »
The Clunk with shifting is normal for a Newbie, It makes this noise due to the Straight-Cut Gears as Youngpup Described, along with a Slight Wining in 5th Gear around 45 mph. As you become more Farmiliar with your Machine, (Valkyrie), you will find that you will learn when to shift so that you can decrease this Hard-Shifting Noise.
Thunderbolt
Worthington Springs FL.
« Reply #6 on: December 09, 2013, 07:21:40 AM »
Ditto what they said Ron.  Make SURE that when you change oil it does not have the friction modifiers in it.  Usually on the back of the bottle there will be a circle with information.  If it says energy conserving do not use it.  Without getting into an oil type discussion too deep.  I now use either Valvoline made for motorcycles which is a little less expensive or Mobil 1 motorcycle oil.  You don't normally change the oil in the bike as often as your car, so give it the good stuff.
FloridaValkRyder
Apopka, Florida
« Reply #7 on: December 09, 2013, 07:35:51 AM »
It took me awhile to get used to certain noises too Ron. I got the opportunity to ride a friends Valk and he rode mine. The noises were the same on his bike and he said my bike sounded normal to him as well. As far as oils decreasing some of the whining, I could tell no difference. My bike came with a good motorcycle oil and when I changed to a full synthetic, I use Amsoil  motorcycle oil, it sounded exactly the same, to me anyway.
I still miss her.
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« Reply #8 on: December 09, 2013, 09:39:04 AM »
When I bought the Valk I asked what oil he was using so I could continue using the same.  He gave me the empty jug and it was Amzoil 20w-50.  I guess it's probably a good synthetic.
YoungPUP
Valparaiso, In
« Reply #9 on: December 09, 2013, 06:07:50 PM »
Definitely check out the shoptalk page. Also check out Chet's FAQ page at the top of shoptalk. Lots of good info there.
