« Reply #1 on: December 10, 2013, 08:05:53 AM » |
Flexzilla by Legacy.
« Reply #2 on: December 10, 2013, 08:14:59 AM » |
« Reply #3 on: December 10, 2013, 08:50:18 AM » |
I wouldn't intentionally steer you wrong. I like these hoses and they work well in weather colder than I want to be in. It is expensive, but, I think it can be bought cheaper locally than those links show unless the cost has gone up that much over the years. The only down side that I see is that it is hard to keep clean.
art
Grants Pass,Or
Grants Pass,Or
« Reply #5 on: December 10, 2013, 07:56:24 PM » |
Flexzilla looks good but it looks to have plastic fittings. Go with the red hose with brass fittings.
Flat6Valk
« Reply #6 on: December 11, 2013, 05:50:24 AM » |
Senco makes a great hose. Skinny and flexible. Go with what the pros use. Im a carpenter and that is the only brand I would recommend.
« Reply #8 on: December 11, 2013, 08:07:31 AM » |
I agree that the fittings look like plastic, but if you read on further you will find they say their fittings are "aircraft grade aluminum", that is anodized to look that "plastic" color. I use a cheap Harbor Freight hose, but only use it seldom, so wrestling with it doesn't bother me too much. ***
« Reply #9 on: December 11, 2013, 10:32:28 AM » |
At the shop we have 4 of those red hoses with the aluminum fittings on celiling reels.
Each hose is run off of the same manifold in the ceiling where the compressor is mounted. The manifold is a one hose in and up to 8 hoses out.
They work like a champ and ya don't have to worry about stumbling all over the those on the floor.
We have had this setup for over 25 years no problems. If memory serves me correctly, we did have to replace 1 of the ceiling mounted reels.
« Reply #13 on: December 11, 2013, 12:58:08 PM » |
At the business we used retractible's, but, at home I have manual 100' reels. There are times I need to get a long way away and need to snap on an extra hose. Whatever you decide on, my recommendation is to get 3/8 hose and not 1/4.
custom1
01 Interstate
SW Pa
« Reply #14 on: December 11, 2013, 01:27:35 PM » |
I'll settle for a "floppy" hose that reaches a bit further than the stiff one I have now...
That should have been the sig line that you usually put after your name.  Couldn't pass that one up.
John
« Reply #15 on: December 11, 2013, 01:29:20 PM » |
That should have been the sig line that you usually put after your name.  Couldn't pass that one up. Dang. Once it's on the innernet, it's committed... -Mike
Punisher
« Reply #16 on: December 12, 2013, 01:51:27 PM » |
.. plus we're starting to get into some real $... I dream about having a reel that works, but I'll settle for a "floppy" hose that reaches a bit further than the stiff one I have now...
Don't act like you're financially challenged, some of us know what area you live in...You Can't Hide Money!
« Reply #17 on: December 12, 2013, 04:03:27 PM » |
The flexzilla hose is great, and the ends are not plastic they are metal. The flexibility is really good and they also flow more air because the inside of the line is actually bigger than a good 3/8ths line. When there is no air pressure in its a bit hard to coil because its not stiff it takes the air to give it any stiffness. Good abrasion resistance doesnt cut easily and another side benefit is they are lighter and easier to maneuver. The have smaller ones you can use as whip hoses for air ratchets and air tools that's really good coupled with a flexible end. It almost feels like there's nothing attached. I was skeptical at first but it really does outperform conventional hoses.
