January 29, 2026, 03:58:39 AM *
Author Topic: LUGGAGE RACK RESTRICTIONS  (Read 1917 times)
KW
West Michigan
« on: July 20, 2009, 04:35:33 AM »
I'm thinking about adding a Leathlyke trunk on my standard. The company website says your rack must be able to hold 30 pounds. . .  The little sticker Honda puts on the rack says; 8 pounds max. I know Honda most likely puts those there for some liability issues? It may also have to do with the weight balance? I've certainly have had well over 8 ponds strapped to the lugage rack before, without any handling issues. . . . and without any damage to the rack or backrest, but I'm wondering if I'll be pressing my luck at 30 pounds? Any input or thoughts would be appriciated. Thanks  cooldude
« Reply #1 on: July 20, 2009, 08:42:43 AM »
I think you'll be alright. I really doubt the trunk weights 30 lbs by itself, loaded maybe.
RudyF6
Chelsea, Michigan
« Reply #2 on: July 20, 2009, 02:00:33 PM »
 Dude, I wouldn't worry - 1st time I took a trip with the wife and our stuff in a sissy bar bag - it had to weigh 45 lbs. My rack fared just fine.
You can never be lost if you don't care where you're going!
98 "Tourerstate" (Std. with I/S bags/trunk)
98 Tourer solo ride
81 CBX
sheets
Jct Rte 299 & 96, Calif.
« Reply #3 on: July 20, 2009, 07:34:22 PM »
I've done 20+ pounds in a T-bag numerous times.  I saw a pic once a number of years ago of a Hondaline rack that failed.  The square frame work is hollow.  It broke right at the end of the side support gussets.  I made an aluminum plate the bolts over the rack to match the foot print of the T-bag.  It helps to distribute the load so the side support gussets carry more of the weight rather than dead weight hanging off the unsupported end.
