January 29, 2026, 03:58:10 AM *
Author Topic: oil blow by  (Read 2091 times)
Tom McInerney
« on: July 20, 2009, 07:23:04 AM »
I just noticed that I am getting oil leaks from around the base flanges of the chrome tubes that come off the manifold and attach to the bottom of each carburator. The worst leaks are from the front tubes on each side. Due I have a serious engine problem or just bad gaskets or O rings. I am not sure how this tube is sealed to the manifold. Thanks
Udo
Germany, Krefeld
« Reply #1 on: July 20, 2009, 07:36:06 AM »
The chromed tubes between the head and the carb? There are o-rings  as sealant between the tubes and the head. You can loosen the tubes at both ends, remove them, and insert new o-rings.
Jeff K
« Reply #2 on: July 20, 2009, 08:10:57 AM »
I'm guessing it is fuel gunk not oil. Put new orings in #123
« Reply #3 on: July 20, 2009, 08:20:34 AM »
Yep. Get a set from redeye-tech on E-Bay. I think they're 13 bucks.
Jeff K
« Reply #4 on: July 20, 2009, 08:55:18 AM »
Or $1 from ace hardware.
Dash #123
Tom McInerney
« Reply #5 on: July 20, 2009, 09:40:47 AM »
You guys are great!!  thanks  Tom
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #6 on: July 20, 2009, 10:05:38 AM »
Yup, what they said. It's a very easy fix. (redeye-tech) on e-bay. or e-mail him @ redeye.rich@gmail.com cooldude
  No affiliation, just a happy customer.
Tom McInerney
« Reply #7 on: July 20, 2009, 04:46:04 PM »
I had trouble locating these at Ace hardware. The orings only went up to #99. i THEN WENT TO ADVANCE AUTO PARTS AND THEY HAD A LOT OF DIFERANT SIZES BUT NO #123  wHAT IS THE OD AND WIDTH OF THESE THINGS? SORRY FOR THE SPELLIN ERRORS   tOM
Bone
« Reply #8 on: July 20, 2009, 05:07:06 PM »
ACCO Hardware had the #123 rings. I always look for things in national chain stores I might need on the road.
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #9 on: July 20, 2009, 05:26:17 PM »
AS568B Nominal Inches Actual Inches Actual Millimeters
Number ID OD CS ID CS ID CS
-123 1-3/16 1-3/8 3/32 1.174±.012 .103±.003 29.82±0.30 2.62±0.08
I got a pack of 25 for around $10 at Granger. Get the Vitron rubber orings. They are gas and heat resistant.
