November 25, 2025, 10:22:18 PM
Installing new petcock
Topic: Installing new petcock (Read 736 times)
snakemeister
Alabama
December 14, 2013, 11:07:48 PM »
I'm about to install a new petcock on my '97 Valkyrie tourer.It's about to turn 100,000 and I've been doing lots to head off a breakdown[fuel lines, brake pads and brake fluid,headlight bulb,rear tire,ect.]
Anyway, I know the carb bowls are empty as is the gas tank and has been for about ten days.
When I put that new OEM petcock on it what's the best way to prime the carbs without grinding on the starter?
98pacecar
Re: Installing new petcock
December 15, 2013, 01:33:52 AM »
Do ya have a mityvac?
https://www.google.com/webhp?hl=en&btnG=Google+Search#hl=en&q=mityvac
If so, you can just hook it to da petcock vac line, pump it ta open da petcock,,,
wait a lil bit,, n' start her right up..
fordmano
San Jose, CA.
December 15, 2013, 02:30:12 AM »
I wouldn't worry about priming the carbs too much, they will fill up fast enough as to not hurt anything.
What Exactly is Normal?
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
longrider
Vernon, B.C. Canada
December 15, 2013, 08:03:58 AM »
These ladies don't pull a lot of vacuum until they are running. When I drain for the winter and the bowls are dry I always pull a vacuum on #6 either with the brake bleeder for a minute or so. doesn't take much to open it.
9Ball
December 15, 2013, 04:17:49 PM »
It takes very little vacuum to open the valve. Just draw a little suction as if you're drinking through a straw, then clamp (or fold) the tubing....this works well and will get the carbs primed.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
December 15, 2013, 04:27:07 PM »
Quote from: fordmano on December 15, 2013, 02:30:12 AM
+1
Also as 9Ball said, it doesn't take much vacuum to pull open the petcock diaphragm.
My rides:
=> InZane XXV
