April 29, 2026, 02:28:10 PM *
Author Topic: Do you hear what I hear?  (Read 2839 times)
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« on: December 15, 2013, 03:30:38 PM »
No, I'm not talking about Santa Claus!  I keep hearing a noise that I just can't pin point where it's coming from.  Could be a mal adjusted timing belt, radiator fan motor bearing, windshield or even my new Baker Wind Wings!  Put your ear right up next to your computer and hold your breath.  Do you hear it?  LoL   uglystupid2
'77 Gold Wing, '81 Gold Wing,
Bert AKA,Valkaholic
Back-N-Black
« Reply #1 on: December 15, 2013, 07:06:53 PM »
When I ride one of our Valkyries, I don't Hear a Thing , Just The Breeze Blowing By.
And That's a Good Thing!
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« Reply #2 on: December 16, 2013, 03:49:30 PM »
Found one of the noises!  The chrome radiator ends and screen were vibrating.  Used some rubber tubing to take the rattle out.  First chance I get I'm going to check the timing belts and see if they are tensioned properly.  Just seems like a similar vibration sound I've heard before.
IamGCW
727 hood
« Reply #3 on: December 16, 2013, 04:34:05 PM »
The Chrome covers are held in place by screws behind the reflectors.  Remove the reflectors and tighten the screws.  They are held on by double sided tape.
Gil
Gil
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« Reply #4 on: December 16, 2013, 05:10:38 PM »
Gil
Thanks Gil.  Learn something new every day about my Valk.  Thanks
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« Reply #5 on: December 17, 2013, 12:33:41 PM »
How do the reflectors come off?  No screws and don't want to force.
« Reply #6 on: December 17, 2013, 12:45:34 PM »
Gil
Ron......  Wink
Bert AKA,Valkaholic
Back-N-Black
« Reply #7 on: December 17, 2013, 12:57:42 PM »
Carefully Pry and Peel them off, tighten the Screws ,Clean all of the exhisting Sticky ,(Double Sided Tape),then apply New Double Sided Tape on them for Re-installation.
IamGCW
727 hood
« Reply #8 on: December 17, 2013, 03:06:12 PM »
I warm mine up carefully with a heat gun (hair dryer should work) and slowly pry them off as Bert does.  I always replace the tape and stick the reflectors back on.
Gil
Gil
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #9 on: December 17, 2013, 03:21:05 PM »
I warm it up with dryer as Gil mentioned, and cut between the reflector and side cover with fishing line using a back and forth sawing motion. Comes off quick and easy. WD-40 will safely remove the remaining adhesive. Then clean and apply fresh double sided tape.
« Reply #10 on: December 17, 2013, 04:46:28 PM »
A little tip with the fishing line. It kinds cuts into the fingers so you might want to wear some tight fitting gloves. No prying needed with the line so you shouldn't be breaking anything.  cooldude
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« Reply #11 on: December 28, 2013, 03:12:07 PM »
Finally got around to hunt down some noise makers.  I was right when I thought the timing belts were not tentioned properly.  Both belts deflected approximately 5/8"!  I adjusted them and it was a trade off for a different kind of noise from the belt area.  Both tentioner's are new.  Maybe I could pack the belt cover with fiberglass!  LoL  The center stand comes up and bangs on the lower exhaust pipe.  I looked underneath and could not find any kind of adjustment so I guess I'll have to manufacture something.
