February 08, 2026, 01:13:56 AM
Starting Question
Topic: Starting Question (Read 1134 times)
old grouch
Colorado Springs, CO
Starting Question
December 22, 2013, 06:57:24 AM »
I have a new to me 1997 Tourer. It will only start in Neutral. In gear with the sidestand up, clutch lever pulled all the way to the grip, the starter does not engage. Is this normal? I seem to remember that my 1999 I/S would start in gear with the sidestand up so long as the clutch was disengaged. TIA Stan
09/11/01 NEVER FORGET!
Re: Starting Question
December 22, 2013, 07:33:06 AM »
It sounds like the clutch switch is not making contact. Remove it and spray some contact cleaner between the contacts. You can see them when the switch is removed. Place a piece of paper between the contacts, close them and pull the paper out which may help clean them. Reinstall switch.
December 22, 2013, 08:26:16 AM »
What Sandy said. Also, when you pull the lever in, you should hear a light "Click". It's the switch in gauging.
If not, the lever or bushing could be the problem.
Also check the wiring, I had a wire work loose from the switch once.
Last Edit: December 22, 2013, 08:31:36 AM by Hook#3287
Chiefy
Sarasota, Florida
December 22, 2013, 09:37:56 AM »
Check that your clutch lever is pulling all the way in without touching the handlebars. If it is touching, the lever can't go far enough to bump the switch. If so, loosen the bolts and move it around some until you can pull all the way without the lever and bar touching. Previous owner may have moved it.
pocobubba
Pocomoke , Md
December 22, 2013, 02:37:16 PM »
I put slip over foam grips on my I/S and the grip does not let the lever switch make contact unless I squeeze it real hard .
old grouch
December 23, 2013, 03:22:20 AM »
Thanks guys. I will check out those fixes. Appreciate the help.
Stan
