February 08, 2026, 08:59:20 PM *
Author Topic: I found my problem today!!!!  (Read 1577 times)
robin
Get on it and RIDE!!
Hardwick NJ
« on: December 23, 2013, 04:14:30 PM »
my problem started at the end of the Fall color ride, i was riding my new to me Interstate that i had bought early this year and after spending a week before the ride in the NC,TN mountains with Rick(flask) i started to hear a sort of clunk coming from the left side when i applied the rear brake thought it was something with the brake boy was i wrong!!!!
This is what i found today after tearing down for winter maintenance.
The whole where axle goes through is a little oblong do you think it would be alright?
« Reply #1 on: December 23, 2013, 04:21:03 PM »
Yeah, put it back together, good for at least another 20 k
SpidyJ
Murrells Inlet
« Reply #2 on: December 23, 2013, 04:29:22 PM »
My 99IS did the same at 28K.  I went with the bearing upgrade and machined spacer on the left side and relaced both sides,  Did a rear end service and replaced the other side bearing and seals too.  MAy as well do the rear brakes while yer at it.
If you decide to go tht route, you will hve heavy duty bearings both sides.
1999 Fast Black Interstate
Peace,
johnnywebb
SpidyJ
Murrells Inlet
« Reply #3 on: December 23, 2013, 04:31:41 PM »
Looks like the bearing race is still in there!
Peace,
johnnywebb
robin
Hardwick NJ
« Reply #4 on: December 23, 2013, 04:38:05 PM »
The race is still in there and i am trying to figure out how to get it out.
« Reply #5 on: December 23, 2013, 05:25:26 PM »
You can get the spacer from Bill ( Grumpy ) and do the double row mod . I've got it on all my bikes and hope I never have another rear bearing issue.
http://www.grumpysfabrication.com/
robin
Hardwick NJ
« Reply #6 on: December 23, 2013, 06:44:02 PM »
Already on it Joe did it to the Pumpkin doin this one to cooldude cooldude
BonS
Blue Springs, MO
« Reply #7 on: December 24, 2013, 05:56:06 AM »
I recently had the same issue with just the outer race stuck in the wheel. Yuk! I had to resort to using a Dremel with a fiber-reinforced disc to cut through the outer race. I took quite a few slices and persuading with a hammer and chisel before the race gave it up. I probably made six different cuts and chinked out the material in between. I didn't want to cut completely through the race because I'd have been cutting into the wheel itself. All that cutting and I only used one fiber reinforced disc. Pretty amazing.
SpidyJ
Murrells Inlet
« Reply #8 on: December 24, 2013, 07:35:04 AM »
I heated the aluminum hub with a propane torch......soft flame.  Then I rubbed an ice cube on the race.......it fell right out.
Merry Christmas!!!!!! Cheesy
Peace,
johnnywebb
« Reply #9 on: December 24, 2013, 01:02:49 PM »
I had the same thing happen to my rear wheel bearing.  I had someone else do it since I was not comfortable with the level of my skills.  Cutting the race out left only a small scar on the wheel and has had no negative result in many, many thousands of miles.
« Last Edit: December 24, 2013, 01:04:25 PM by Willow » Logged
robin
Hardwick NJ
« Reply #10 on: December 24, 2013, 01:11:16 PM »
I took the wheel today to the mechanic that does work on my sons dirt bike and he did get the race out!!!
Nice guy did the fork seals on my other valk with no problems.
Michael K (Az.)
Glendale, AZ
« Reply #11 on: December 24, 2013, 01:41:41 PM »
That very pain was felt for me last summer on my "July and let's try to avoid Death Valley and hang in Mammoth Lakes" ride! Middle of nowhere and bearing starts singing a (not) happy tune! sigh!
hal47
INDIANA
« Reply #12 on: December 24, 2013, 03:16:21 PM »
Robin make sure the bearing presses in tight, hey thanks again for the flash light,really like it.
« Reply #13 on: December 24, 2013, 03:37:10 PM »
I'll second that .... The one you gave me this year at The Fall Color Ride is a damn nice flashlight  cooldude  Merry Christmas my Yankee friend  Smiley
Flask
Inglis Florida
« Reply #14 on: December 24, 2013, 05:45:27 PM »
I will 3rd that - Use it a lot !!!!!!
eric in md
« Reply #15 on: December 24, 2013, 06:29:15 PM »
 Undecided Undecided Undecided humm flashlights ?  wheres my girlfriend.
