February 08, 2026, 01:13:03 AM *
Author Topic: Super Valk tail light  (Read 1080 times)
SloRider
« on: December 27, 2013, 06:07:14 PM »
I'm in the process of pulling the trunk. I have everything disconnected but the tail lights. Is the connector behind the fuse mount in that plastic shroud? It's tough to get to and took me a long time to find. Also, when it's time to wire the new tail light can I just plug it back in and tap into that wiring? Hoping to dig into it tomorrow during this Michigan permafrost.
« Reply #1 on: December 27, 2013, 06:42:21 PM »
All depends on what you want to do.
From the main harness behind the RH side cover, there is 2 sets of wires for the rear lights.
There is 2 for the IS model, and 2 different ones for the Std/Tourer models. At the main harness, they  are the same.
So, you can go out and buy there 2 sets for a Std/Tourer, and plug them into your IS, and connect to the Std/Tourer brake/tail lights.
« Reply #2 on: December 27, 2013, 07:00:42 PM »
I just spliced into the harness behind the right side cover. Actually used the harness off my trunk and ordered a new one to replace the one I cut up. I recently put my trunk back on and still have the tail light working.
