This has happened four times now & I don't know what is the problem. Out of gas? w/ 1/2 tank left. First time in Aspen, 4 July, 85* stop & go traffic, filled up took 4.3 gal. Next time 3/4 way up Monarch pass, 65* same thing, go on reserve, runs great. Third time between Alamosa & Fort Garland. Go on reserve, runs fine, 4.3 gal at fill up. Fourth time nearly home, 1/2 tank on guage, go on reserve...... Vent line is connected, not kinked, stock ECM as far as I know, so what do you think? Time for a petcock rebuild/replacement, or cleaning or what? Thanks in advance for your help. Stan
sounds like the petcock vacuum diaphragm is leaking. search for my posts on the subject. put a new diaphragm in and install a snubber in the vacuum line. It most likely will never wear out again.
Mine was worn out at 15k miles
