February 08, 2026, 04:28:09 AM *
Author Topic: Coolant Leak - Advice  (Read 2813 times)
DarkSideR
Pueblo, Colorado
« on: December 30, 2013, 09:30:40 AM »
Last Saturday the temp got up to a blazing 59 degrees so I decided to take the Valk out for a ride. After sitting for 3 weeks in the garage, I started the bike to warm it up. Got my jacket, gloves, and helmet. Upon coming back to the bike I found a small puddle of coolant under the the left corner of the belt cover (when the bike is on the kickstand the drips came from the lowest point).
I looked above that point around the hose connections and didn't see anything obvious. So I wiped the coolant drips from the cover and went to get a flash light to further investigate. 2 minutes later with the bike still running no more drips to be found.
I checked the coolant level, and rode 60 miles keeping an eye on the dummy light. I got back home and checked the coolant level again to find it the same as before the ride, so it hadn't leaked anymore. The bike is an 2001 with only 36k on it.
My thoughts are the leak came from inside the compartment where the belts are. The very cold conditions caused the leak  Undecided.
Can you please give me your thoughts or similar experiences. Being winter I would like to do any necessary work now than during the riding season. Thanks.
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
« Reply #1 on: December 30, 2013, 09:45:55 AM »
Coolant is not routed to the timing belt compartment.  Almost certainly, coolant came from a radiator hose clamp, and ran down with gravity to the lowest part of the bike on the left kickstand side.  This would be mostly internal and hard to find evidence from looking while on hands and knees. As soon as she heats up, the cooling system expands with heat and the leak stops.
This is pretty common, and you could probably get a half dozen small occurrences over a cold winter months, and yet never be able to detect an overall loss from your coolant reservoir.
I would not worry if it does not continue, or go after the radiator hose clamp.
There is not a well-documented history of our radiator hoses going south, yet.... but as the years continue to roll by, there probably will be.
« Last Edit: December 30, 2013, 09:48:42 AM by Jess from VA » Logged
Joe Hummer
Arnold, MO
« Reply #2 on: December 30, 2013, 09:48:18 AM »
Hey Josh,
Dude...that bites.  You had best just bring the bike to me in St. Louis.  Be sure to bring the title too...I will need that when I strip it down for parts...the frame would be worth more then.
Seriously...chances are...it was the hose connection at the block.  Those are known to leak from time to time.  Nothing to get too concerned about...if you can get into the clamp, tighten it a little.  If it is the spring type, replace with a screw type.
Joe
1999 Valkyrie Interstate
DarkSideR
Pueblo, Colorado
« Reply #3 on: December 30, 2013, 10:16:04 AM »
Joe,
I thought about scrapping it because of this..
But I guess I will check a hose clamp or two before I hand her over.
VRCC#34410
VRCCDS#0263
Old Geezer Richard
San Antonio , Tx
« Reply #4 on: December 30, 2013, 12:28:26 PM »
  Hey Josh , I had the same drip of coolant from the left side of the engine after I would come home from a ride ... I also checked the coolant level and it was fine .... I got my friendly nut driver and tightened down the hose clamps and the drip has stopped .... Check your hose clamps ... Thanks the Geezer  crazy2
DarkSideR
Pueblo, Colorado
« Reply #5 on: December 30, 2013, 12:40:05 PM »
And that's what I was looking for.  cooldude Commence operation tightening hose clamps.  Smiley
VRCC#34410
VRCCDS#0263
DarkSideR
Pueblo, Colorado
« Reply #6 on: December 30, 2013, 04:03:33 PM »
I found the leak. The culprit is the hose clamp that is top, center of the engine right behind the radiator. Looks like I will have to pull the radiator to get at it.
VRCC#34410
VRCCDS#0263
« Reply #7 on: December 30, 2013, 04:05:27 PM »
Believe it can be loosened from a single top bolt and swung forward enough to get a tool in without having to pull it.
DarkSideR
Pueblo, Colorado
« Reply #8 on: December 30, 2013, 04:08:09 PM »
Jess, I am greatly hoping you are right.
« Last Edit: December 31, 2013, 06:45:39 AM by Joshcornkid » Logged
VRCC#34410
VRCCDS#0263
olddog1946
Moses Lake, Wa
« Reply #9 on: December 31, 2013, 09:41:10 AM »
He is indeed, correct. No need to remove the radiator. I loosened mine,  then loosened the clamp and turned it so I can get to it from the side without having to mess with the radiator, using a long handled nut driver or socket/extension.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
O-B-1
Vancouver, WA
« Reply #10 on: January 04, 2014, 09:07:07 PM »
Hey Rick, how are you and... Was it Gary? The Navy guy, doing? Holding up well in this cold? I have the darn crud that is going around, severe sinus and chest congestion. Feeling much better, now.
My bike is doing this just sitting in the 19 degree weather under the carport. I saw it was running down from the fitting where the hose enters the block.
Looks like I need to check the clamp up top, also.
We should get together with my friend Jim and have a Valkyrie luncheon sometime... Maybe when I am well and it warms up! LOL!
David W. Mitchell
1999 Honda Valkyrie GL1500C
Karen
Boston MA
« Reply #11 on: January 04, 2014, 09:17:37 PM »
Josh, they are correct, even I was able to tighten the inside hose clamp with minor grimacing & cursing.
DarkSideR
Pueblo, Colorado
« Reply #12 on: January 05, 2014, 01:35:17 PM »
I did it. The radiator pivots forward with minimal effort. I turned the hose clamp around so it can be tightened from the side without having to work around the radiator.
Now I just have to figure our how to get my bike to Tulsa so Attic Rat can work his magic on my motor.
« Last Edit: January 06, 2014, 06:16:47 AM by Joshcornkid » Logged
VRCC#34410
VRCCDS#0263
