November 25, 2025, 10:47:09 PM *
Author Topic: Pic of fuel shut off install.  (Read 820 times)
98pacecar
« on: January 10, 2014, 07:52:31 AM »
I've seen a pic of typical Dan-Marc plumbing, of fuel lines,,, posted here in da recent past.  coolsmiley
Am getting ready to ride to NAPA ta pick up da required brass fittings,
 n' fer da life of me,, can NOT locate dat pic.    tickedoff
Anybody know where I might locate it?     Cheesy
Thanks,, Jim
rekit
Let's Go!
77532
« Reply #1 on: January 10, 2014, 08:15:54 AM »
http://www.horseapple.com/Valkyrie/Tech_Tips/Fuel_Shutoff/fuel_shutoff.html
Bought a brand new Z1 in 74 and sold it later to get a "family car" DOH!! My brother had a Kaw H1 at the time as well. Oh well, good times! Lately Mean Streak, CBX, Nighthawk 750, Connie, KZ1000, Yamaha TTR 250, KTM 250
98pacecar
« Reply #2 on: January 10, 2014, 09:11:39 AM »
Dat's, da one.........   cooldude
Thank you, very,,,,,,,,,,,,, much,, Jim   Smiley
Rebyl
Lifes to short to have regrets
Taumarunui, New Zealand
« Reply #3 on: January 10, 2014, 11:42:30 AM »
I have never bothered to turn off the fuel on my Valks, has never caused a problem.
Hope you find your solution soon.
I do believe we have consistent and good quality fuel down here, I can run 91 or 96 and notice no difference. On my trips to the States I did notice a big difference in some areas, especially out in the back blocks of nowhere, but guess that's understandable.
Punisher
No, not vengenance. Punishment.
« Reply #4 on: January 10, 2014, 11:45:18 AM »
Apparently we've all bought so many of these Fuel Valves from ol' Dan he even mentions its use against Hydro-lock on a Valkyrie and a link to MarkT's tech article
http://www.dan-marc.com/79-afc11112.html
[snip]
12 Volt Multi Fuel Shut Off Valve
Engineered for use in automotive, diesel, industrial, temperature and dispensing control applications.
Protection from Valkyrie Hydrolock.
Features and Specifications: Rated working pressure 0-30 PSI. 2-way normally closed inline solenoid. Orifice size .156" for adequate flow of all fuels. 100,000 cycle tested. Extensive test data available. Minimum draw - only .75 amp, 12 VDC when fully energized. OEM approved. Easy installation - 1/8" female pipe threads, inlet and outlet. Ambient temperature rating -40°F to +250°F, or 170° Fluid. Heavy duty construction, corrosion resistant - solid brass and plated steel. Rated for use with diesel fuel, Gasoline, Propane, Natural Gas, air, and other media. All valves are date coded. Every unit 100% functionally tested for low/high pressure leaks and dielectric breakdown. Great for Diesel fuel auxillary Tanks. Safety Rated
This valve is featured on the following Valkyrie Tech site.
[/snip]
