April 29, 2026, 07:43:59 PM *
Author Topic: Fork seal leak  (Read 2596 times)
longrider
Vernon, B.C. Canada
« on: January 12, 2014, 08:50:00 AM »
Wife and I will be spending some time in your area this winter.  Jan 27 - Mar 13.  On our way down now (Phoenix) from British Columbia Canada.  Thought I had both bikes in tip top shape but the valk has developed a fork seal leak.  Now I know this may be a stretch but if any of you have a lift, seal driver, and could spare the time I would do the job myself.  left the seal driver at home and no room for the lift!.  I just don't like letting the stealer touch the bikes.
Warren
#5054
TJ
Lake Placid , Fl.
« Reply #1 on: January 12, 2014, 09:14:18 AM »
Florida is a big state so it might help if you said where you are going to be at....
Thunderbolt
Worthington Springs FL.
« Reply #2 on: January 12, 2014, 09:15:47 AM »
Hi Warren, sorry your bike has developed a problem.  I won't volunteer anyone in particular, but know that a couple of folks on the board have done this and have the equipment.  Luckily I have not had that problem to this point, so no experience on that procedure.  I would bet that someone will volunteer to help.  I don't know what part of the state you end up in, but if no one else speaks up I have a lift, but no seal driver.  I wouldn't mind learning the process.  I am 20 miles N. of Gainesville however in the cold Northern part of the state.
 Smiley
Pappy!
Central Florida - Eustis
« Reply #3 on: January 12, 2014, 09:43:27 AM »
Also, have you tried the 35mm film trick ? See if there is just a stuck piece of debris there?
longrider
Vernon, B.C. Canada
« Reply #4 on: January 12, 2014, 09:58:51 AM »
Thanks gentlemen for the replies.  We will be enjoying Floridas beautiful State Parks.  Starting with Stephen Foster Folk cultural Center (1 week) and then on to Silver Springs (2 weeks) and  finally Lake Louisa (2 weeks).   Thunderbolt,  Sounds like we will be near you.  I will need to come up with the driver and a set of seals.  Is there a local honda dealer nearby.  Maybe I could borrow their driver.
Thunderbolt
« Reply #5 on: January 12, 2014, 10:30:46 AM »
Interstate Honda is in Lake City Fl.  Streits Honda is in Gainesville.  You might try the film trick that Pappy mentioned first.  Or a plastic soda bottle cut into a shape that might fit between the seal and the tube.
Bert AKA,Valkaholic
Back-N-Black
« Reply #6 on: January 12, 2014, 12:39:01 PM »
Hi Longrider I Live 17 Miles East Of Silver Springs  Just South Of SR-40 And I Have A Jack And Tools To Do The Job, Except A Seal Driver. From What I Have Seen One Can Easily Be Made From A Piece Of PVC. I Am Around The House During The Week And May Be Able To Assist You .When You Get In The Area You Can Call Me @ 352-625-6 Four Four 8.
I Have To Replace The Seals On One Of My Valk's This Week And Will Make and Have A Seal Install Tool on Hand.
There Is Also A Honda Dealer In Ocala To get Parts And Fork Oil. They Will Also Match Honda Directline's  Prices On Parts.
Bert
« Last Edit: January 12, 2014, 01:08:01 PM by Bert AKA,Valkaholic » Logged
« Reply #7 on: January 12, 2014, 01:02:40 PM »
Two years ago my right fork seal started leaking badly on the way to inZane.
With all the help at ground zero, I obtained a lift, seals, fluid, tools, a manual,
a driver and rebuilt the leaker in the parking lot, and it worked great.
Last year on the way to inZane my left fork started leaking badly, and Trout Dude
and Mitch ran the sealmate tool on my fork while drinking a beer, and it
worked great.
I'll never foo-foo "the film trick" again, it is not snake oil... and, when it works,
is lots better than rebuilding a fork on the road.
FloridaValkRyder
Apopka, Florida
« Reply #8 on: January 12, 2014, 04:02:16 PM »
When Bill rebuilt my forks, he used a piece of 1 1/2" pvc pipe he has cut to drive the seals in. Worked like a champ.
I still miss her.
« Reply #9 on: January 12, 2014, 04:14:20 PM »
I found it was this schedule 40 coupling that did the trick...
FloridaValkRyder
Apopka, Florida
« Reply #10 on: January 12, 2014, 05:02:20 PM »
Probably was Mike, I knew it was 1 1/2 half something  cooldude Worked very well for him..and was super cheap to get!
I still miss her.
« Reply #11 on: January 12, 2014, 05:12:48 PM »
It might be a 1 1/2 coupling... when I tried to tell someone once what size
it was, I remembered wrong, that's why I took that picture... a coupling goes
on the outside of the pipe, so that's probably not a 2 inch coupling... anywho,
that picture shows how to measure for the right sized coupling...
longrider
Vernon, B.C. Canada
« Reply #12 on: January 12, 2014, 07:45:38 PM »
Well, went to visit my brother here in Phoenix this aft.  He has a 99 IS I work on.  Maybe last sept he had a seal go and bought a pair.   I only installed one.  He still had the spare in his bag so I am set for parts.
I will let you know when I arrive at Stephen foster
Warren
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« Reply #13 on: January 15, 2014, 08:09:00 AM »
Here's a pic of the Seal Mate.  Might well be worth the money, $5, if it's only a dirty seal rather than a bad seal.
'77 Gold Wing, '81 Gold Wing,
