November 19, 2025, 04:11:54 PM *
Author Topic: Rear wheels interchangable between years?  (Read 1778 times)
Garland
#618
Hendersonville NC
« on: July 23, 2009, 06:20:24 AM »
I have a 99 Tourer, and was looking to pick up an extra rear wheel just to have on hand as a spare.  HDL has different part numbers for different years-at least between the 99 and 01 models I compared. Anyone know of differences in both rear and front wheels from year to year?
TIA
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: July 23, 2009, 06:28:53 AM »
The 01 through 03 front and rear wheels on the standards/tourers are different. The centers of the wheels are a bit thicker near the hub and they are polishised and clearcoated.
The 99 front wheels use smaller wheel bearings.
ALWAYS QUESTION AUTHORITY!
Garland
#618
Hendersonville NC
« Reply #2 on: July 23, 2009, 07:36:03 AM »
Is there a problem with using a later model wheel on my bike in terms of fitting or not?
« Reply #3 on: July 23, 2009, 08:31:46 AM »
I understood it was the 97 that had smaller front bearings.?.
I believe you will find no problems with mounting any year rear wheel.
« Reply #4 on: July 23, 2009, 09:11:31 AM »
I/S wheels won't work unless ya take the disc and the caliper with it.
I have used an 01 Std rear wheel on my 97 Tourer,
I did not know for sure so we expiermented with a buddies bike during his tire change,,,,
Give it a try and change parts as needed,,,,,,
MP
North Dakota
« Reply #5 on: July 24, 2009, 05:25:28 AM »
97 front wheels smaller bearing, although I understand late model 97 may have larger ones.
On rear, if you use the correct year brakes with the wheel, all will fit.
MP
"Ridin' with Cycho"
