March 14, 2026, 10:11:27 AM *
Author Topic: Showing Off  (Read 4594 times)
Valkpilot
What does the data say?
Corinth, Texas
« on: January 16, 2014, 11:10:07 AM »
When I got the Jet bike, it had a lot of electrical mods and add-ons, including a novelty back-up beeper.  I could hardly figure out what was going on in the battery compartment, the headlight bucket, and under the right sidecover.
So, I put her up on the lift, stripped her down, gutted everything except the stock wiring and replaced the add-on wiring with this:
The fuse panel is an Ancor Marine Grade box from Amazon: http://www.amazon.com/gp/product/B000NI3CM2/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
The relay and relay connector is also from Amazon, available in packs of 5: http://www.amazon.com/gp/product/B005HFYE1O/ref=oh_details_o03_s00_i01?ie=UTF8&psc=1
The green wire comes from the negative battery terminal and connects to a ground bus on the fuse panel.
The red wire comes from the positive battery terminal and connects to the +12 in blade of the relay.  It is fused.
The black and white wires connect to the accessory circuit (inside the black boot) and are used to trigger the relay.
Total cost is about $35 and you've got 4 more relays and harnesses to use for driving lights, head light, horn, and whatever.
In addition, I ran a ground wire from the new fuse panel to the headlight bucket. (The frame ground pass through to the bucket can be iffy because of the bearings in the steering head.) The relays for the driving lights and headlights are in the bucket and are now grounded to the bucket mounting bolts.
I also ran three spare circuit wires from the fuse panel area to the headlight bucket.  These are capped and coiled at each end, ready and waiting if I need to add something new.
The bucket ground, headlight, horn, and driving light relay power, and spare circuits are all neatly in corrugated conduit.
The black bike is next...
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #1 on: January 16, 2014, 11:34:40 AM »
That looks good.
I recently had a problem with the way I wired up my fuse box six years
ago: I didn't put all the wires in looms and one of them rubbed through
and shorted stuff out.
I redid it with a PDM60 instead of a fuse box. The PDM60 fit under the
seat, but I still have a tangle of loomed wires under tail end of the gas
tank  Undecided I trapped the untangled PDM60 outputs under the old velcro
straps that used to hold the CB in place...
-Mike "wiring up stuff is fun"
Valkpilot
Corinth, Texas
« Reply #2 on: January 16, 2014, 12:43:34 PM »
That looks good.
That's a nice clean look.  I couldn't use that space though because the Jet bike has the OEM CB sitting on top of the battery.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
saddlesore
« Reply #3 on: January 16, 2014, 12:51:34 PM »
Thanks for the links.  It's a place to start for me, I need to clean things up myself.  Redid it before but things look sloppy again.  Embarrassed
DARE TO BE DIFFERENT
« Reply #4 on: January 16, 2014, 01:31:09 PM »
For fear of being mocked endlessly, I will not allow any cameras near the rat's nest I've created under the seat of my Valk...
Very nice work!
Valkpilot
Corinth, Texas
« Reply #5 on: January 16, 2014, 01:39:46 PM »
Very nice work!
Thanks.
As far as being mocked is concerned, there are a lot of glass houses out there, including the one that encloses the black bike.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
chauffeur
Mansfield, Texas
« Reply #6 on: January 16, 2014, 02:49:50 PM »
looks great.  Has officially been added to my "to do" list.
Red Diamond
Beaumont, Texas
« Reply #7 on: January 16, 2014, 03:17:30 PM »
Never laid eyes on the Jet Bike, bet there is some red on it somewhere. How bout a pic or two or three. Sounds like you have that wiring down to a science.
Valkpilot
Corinth, Texas
« Reply #8 on: January 16, 2014, 04:19:40 PM »
Never laid eyes on the Jet Bike.... How bout a pic or two or three.
Here you go, Eli.
http://www.valkyrieforum.com/bbs/index.php/topic,44404.msg421861.html#msg421861
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #9 on: January 16, 2014, 05:31:19 PM »
That yellow bike might be the best looking non-OEM paintjob I ever saw  cooldude
godfire
Republic of Texas
« Reply #10 on: January 16, 2014, 06:04:03 PM »
well, why didn't you do it right?
Ride Safe
Ride Often
Valkpilot
Corinth, Texas
« Reply #11 on: January 16, 2014, 06:30:49 PM »
Thanks.
I like yellow bikes, but it's a polarizing color -- people either really like it or really don't.
The ones that don't give me a pass because I've also got one in fast-black.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Valkpilot
Corinth, Texas
« Reply #12 on: January 16, 2014, 06:31:14 PM »
I was probably stupid that day!
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
YODA MASTER
CASTLE HILLS (Carrollton/Lewisville Texas Area)
« Reply #13 on: January 16, 2014, 06:41:15 PM »
Ain't nobody giving you pass on da yeller scooter, VP. YELLOW on a Valkyrie is YUGLY!
JC ALLEN
VRCC 22906
'03 BLACK 'HOWIEFIED' VALKYRIE
'99 BLACK VALKYRIE INTERSTATE SUPER VALK
'14 ALL BLACK GOLD WING - ALL BAD
Valkpilot
Corinth, Texas
« Reply #14 on: January 16, 2014, 07:00:26 PM »
Well, present company excluded, of course.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
SideCar
Bikers don't need shrinks!
Colleyville, TX
« Reply #15 on: January 17, 2014, 11:46:53 AM »
Nice and clean looking.
Yes, mine is a rat's nest under the sidecover, but it keeps running and the lights are working. Where's the smiley with the crossed fingers
« Reply #16 on: January 17, 2014, 01:25:14 PM »
I like yellow too.  cooldude
It is only a Bumble.
A Bumble Bee would require more black.
I do like the minimalist black striping as well.
« Last Edit: January 17, 2014, 01:27:16 PM by Jess from VA » Logged
Valkpilot
Corinth, Texas
« Reply #17 on: January 17, 2014, 05:12:47 PM »
Thanks, Jess.
Disco rides a Bumble Bee.  We ride together a lot, so don't want to look too much alike.  People might talk.  Not that there's anything wrong with that. angel
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Valkpilot
Corinth, Texas
« Reply #18 on: January 17, 2014, 07:04:21 PM »
Here's the tank from my Spirit 750, repaired after an unfortunate get off.  It's a rattle-can paint job with a decal under the clear coat.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #19 on: January 18, 2014, 12:24:40 AM »
Here's my old '86 FXRD with new black paint and bas relief decal under clear coat.
The pic may later disappear (Delphi)
Valkpilot
Corinth, Texas
« Reply #20 on: August 26, 2017, 03:15:45 PM »
Finally stripped all the old accessory wiring out of the black bike and upgraded it with an accessory panel.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Red Diamond
Beaumont, Texas
« Reply #21 on: August 26, 2017, 05:56:18 PM »
That's really neat VP, hope you won't mind me copying your setup for my tourer.
Valkpilot
Corinth, Texas
« Reply #22 on: August 26, 2017, 08:01:59 PM »
Go for it, Eli.  Wish I'd done it a long time ago.
Here's the stuff I used:
https://www.amazon.com/Seachoice-ATO-Fuse-Block-Gang/dp/B000N9PJ7W/ref=sr_1_20?ie=UTF8&qid=1503803338&sr=8-20&keywords=marine+fuse+panel
https://www.amazon.com/CrazyEve-Waterproof-Automotive-Harness-Sockets/dp/B01HJFDJ8S/ref=sr_1_2?s=automotive&ie=UTF8&qid=1503803501&sr=1-2-spons&keywords=automotive+relay&psc=1
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
SideCar
Colleyville, TX
« Reply #23 on: August 27, 2017, 07:19:59 AM »
Wish my wiring was that clean. Nice job.
Valkpilot
Corinth, Texas
« Reply #24 on: August 27, 2017, 02:28:40 PM »
Thank you.  And yours can for an afternoon of head scratching and smoke testing (sometimes you have to let the smoke out of the system a couple of times to get it to work right!)
Did the Wing a couple of months ago.
Part of what motivates me is beside-the-road troubleshooting.
Having been through a couple of those situations (although not electrical) the stress and anxiety can make clear-headed thinking difficult.
Trying to unravel a rat's nest of unmarked wires while parked on the shoulder with cars going by at 80 MPH is just something I don't care to put myself through.  At least this way, I know what goes where.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
