February 08, 2026, 04:49:42 AM *
Author Topic: Rusty seat lock cable  (Read 965 times)
cokebottle10
Green and Silver 99 I/S
Fletcher NC
« on: January 27, 2014, 04:05:09 PM »
I went to install external cables for my new Ctex charger and could not get the seat to unlatch. Angry I ended up having to take the coolant tank loose and use a long screw driver to tension the cable at the latch. I then removed the latch, cable and lock. The cable was rusted but with it out of the bike I was able to get it free. I guess because the cable is mounted in a U shape with the ends pointed up, water can collect in the bottom of the U.
I used electric contact cleaner to get most of the rust out. Then 3 in 1 oil to lube it. When I installed it back in the bike (what a pain) the latch would not fully open. I had to pull the cable back off the lock and remove the lock along with the metal mount that holds the cable on that end. The metal mount was bent a little. I put it in my vise and straighten it back out. I guess it got bent when I was trying to get the cable to move.
This is the second time I have had problems with the seat lock. The first time I got it unlocked when I finally pushed down on the seat. uglystupid2 Anyway, I have a new cable on order from the dealer for less than $8.00. cooldude
Thanks, David in Fletcher NC
Otus
Scott
Taylor Mi.
« Reply #1 on: January 28, 2014, 04:26:08 PM »
Mine seems not to want to open when the bike is warm, but when its cool it pops right open.
