January 29, 2026, 05:30:47 AM
Interstate Intercom stopped working
Topic: Interstate Intercom stopped working (Read 2216 times)
lilgeo
St. Augustine, FL
July 24, 2009, 01:14:23 PM »
Hello,
I have a 2000 Valk Interstate with the installed intercom and CB radio unit. I have J&M headsets in both mine and my wife's helmet. They worked great for 3 years then last year, the microphone in my helmet stopped working. I thought it was the headset so I bought a new one (before swapping them to check!).
Same problem with the new set. The mic works when hooked to the rear i/c input but not on the front.
I traced the wire into the fairing but after that, I have no clue.
A wiring diagram would help or if anyone has any ideas they would be greatly appreciated.
Thanks!
George
PatrickDoss
Alabama
Re: Interstate Intercom stopped working
July 24, 2009, 05:35:29 PM »
Did you swap the cords also, or just the headsets? The J&M cords are prone to failure.
Rocketman
Seabrook, Texas
July 26, 2009, 09:30:36 PM »
Check all the pins on the cord. One of mine broke a pin off. Very annoying, as the pin stuck in the other connector, and made contact intermittently.
lilgeo
St. Augustine, FL
July 29, 2009, 08:57:17 PM »
Yes, I tried a different cord. Also, when I hooked it up in the back, it worked fine.
Joe Hummer
Arnold, MO
July 30, 2009, 04:47:08 AM »
sounds to me you have the same problem I do. The cord from the fairing to your headset lower cord is bad. I have a new cord on the way from RonAyers.com. $40ish.
Item 11...
Radio Fiche
I will let you know if this fixes my problem.
Joe
1999 Valkyrie Interstate
lilgeo
St. Augustine, FL
July 31, 2009, 04:17:46 AM »
Thanks Joe,
I took my fairing apart yesterday and checked the continuity from the plug end to the red connector behind the fairing. Everything checks out good there. I just don't know where to go from there without a wiring diagram and am really not looking forward to pulling the tank to trace wires.
George
