November 19, 2025, 04:09:02 PM *
Author Topic: Another oil question.  (Read 2064 times)
« on: July 24, 2009, 03:53:05 PM »
I have been using Mobile 1 Synthetic 10w-40 'high mileage' for about 15,000 miles. I like it but some say its to thin. Is it? Going to Sturgis next week and like to change oil before I leave and when I return. All highway and interstate. Temps around 90-100. I finally found Rotella synthetic but its a 5w-40. Is this ok? Or should I try the Delac(sp) 15w-40 oil?
« Reply #1 on: July 24, 2009, 03:58:41 PM »
Put the Mobil 1 in it and forget about it.
MGM has had more Mobil 1 run throught it than about 4 normal bikes.
No firkin problems,
@ 242,000 + change I'm starting to get some smoke at start up, but I blame it on valve seals.
six2go #152
Ft. Wayne, IN
« Reply #2 on: July 24, 2009, 05:16:28 PM »
Fudgie, any oil which is rated at ??w40 will be 40 weight oil at operating temp. The number before the w is the viscosity at 0 degrees. You don't ride when it's 0 do ya?
« Reply #3 on: July 24, 2009, 05:59:36 PM »
RJ,
checkout http://auto-rx.com/index.html    I can attest that it works like stated. Haven't used it in the bike but am using it in my 99 dakota 5.2L. The engine had a blow-by problem, which now has subsided after the auto-rx treatment.
u can read many more actual cases at www.bobistheoilguy.com
Madmike
Campbell River BC, Canada
« Reply #4 on: July 24, 2009, 06:10:56 PM »
Here is some reading on motor oils  and how they try to achieve different qualities when they formulate them.  The sections on Viscosity Index Improvers and synthetics may help you in making a decision on what oil you want to run.
http://www.bobistheoilguy.com/index.php?option=com_content&view=article&id=51&Itemid=58
http://www.bobistheoilguy.com/index.php?option=com_content&view=article&id=53&Itemid=61
« Last Edit: July 26, 2009, 11:19:15 AM by Madmike » Logged
« Reply #5 on: July 24, 2009, 06:15:25 PM »
Ok now that makes sense. Never understood what it all meant. Think I'll leave it in and change it when I come back unless theres some specials running. Only got 3,000 miles on this oil. Missed ya at the cookout last weekend.
Grandpot
Fort Mill, South Carolina
« Reply #6 on: July 24, 2009, 06:24:22 PM »
I use Mobile 1 in my cars and trucks.  Change the oil every 20,000 miles.  No problems.  Do not need to add oil between changes.
I now use Mobile 1 MC oil in my bikes.  I change the oil every winter.  Grin
