February 08, 2026, 04:49:46 AM *
Author Topic: rear brakes after tire change  (Read 1136 times)
mrmessy
Clarkdale, Arizona
« on: January 31, 2014, 06:29:21 PM »
Help, I changed my rear tire and went through all the steps by the book. had a little trouble getting the brake caliper on but it finally went. After all was done, I went to set the brake pads and the pedal would not move. It is locked up. tried forcing it and managed to lock up the breaks. Had to oped bleed line to release the pads. Any ideas as to what happened. Took caliper off to check and saw nothing wrong. Pedal still locked up. Need advice.
« Reply #1 on: January 31, 2014, 07:21:10 PM »
maybe too much fluid in there.  If you had topped off the master and then compressed the pistons.....well bad stuff can happen
mrmessy
Clarkdale, Arizona
« Reply #2 on: January 31, 2014, 07:45:42 PM »
breaks worked fine before the tire change
pancho
Bonanza Arkansas
« Reply #3 on: February 01, 2014, 03:23:07 AM »
When you were having a hard time getting the caliper back on, that was a sign that you needed to compress the pistons back into the caliper a bit. Try removing the caliper again, compressing the pistons a bit, and trying again.   Use a clamp, make sure to have a pad in on the piston side to clamp against, and remove the top of the master cylinder to monitor the fluid level. Since you need to do all that, I would push the cylinders MOST of the way out to clean all the gunk and contamination from them before compressing them back in.
98pacecar
« Reply #4 on: February 01, 2014, 06:05:43 AM »
Is there a spacer/washer,,, possibly in the wrong location, or missing?   coolsmiley
 I have yet,, ta pull my valk rear wheel, but have had a similar problem on other bikes...    Embarrassed
If the wheel (or caliper) is off,,, to the left or right,,, it will cause,, what you are seeing...
« Reply #5 on: February 01, 2014, 07:51:41 AM »
The pistons should go back into the bores easily. It sounds to me as though somehow the wheel was installed incorrectly.
« Reply #6 on: February 01, 2014, 08:33:27 AM »
You could have crap in the brake line that pushed back into the master cylinder when you reinstalled the caliper.
First thing to do is locate where the problem is!
A brake bleed would eliminate the master cylinder from the mix.
Proceed as necessary.
mrmessy
Clarkdale, Arizona
« Reply #7 on: February 01, 2014, 11:20:53 AM »
problem solved, there was crap in the line. must have dislodged when movine breakline around while reinstalling the caliper.
