February 08, 2026, 04:49:50 AM *
Author Topic: Are Interstate headlights adjustable?  (Read 1016 times)
rekit
Let's Go!
77532
« on: February 04, 2014, 04:39:21 PM »
I looked in the manual and did a search-nothing.
Bought a brand new Z1 in 74 and sold it later to get a "family car" DOH!! My brother had a Kaw H1 at the time as well. Oh well, good times! Lately Mean Streak, CBX, Nighthawk 750, Connie, KZ1000, Yamaha TTR 250, KTM 250
Red Diamond
Beaumont, Texas
« Reply #1 on: February 04, 2014, 05:20:00 PM »
yes, just remove the speakers to access the adjusters at rear of the sockets.
saab9k
« Reply #2 on: February 04, 2014, 06:08:44 PM »
Thanks, will remember that.
« Reply #3 on: February 04, 2014, 06:43:42 PM »
IF you have NEVER removed the little bolts that hold the speakers in-yer in fer a treat!!  tickedoff They thread into brass inserts that are pushed into the plastic of the fairing. AND I'm relatively certain they WERE NOT treated with anti seize before installation.  crazy2 The bolts will turn the inserts instead of backing out like they should.  Lips Sealed IF you have zero trouble getting them out-you are in a minority.  Grin Prior to reinstalling some anti seize is called for.  cooldude RIDE SAFE.
« Reply #4 on: February 04, 2014, 08:07:22 PM »
You can adjust the lites thru the access panels on the back side of the fairing, one on each side.  Small, agile hands are an asset to say the least.  There is an adjusting knob behind each side.  Access for bulb replacements are there too.  ???  Hoser
« Reply #5 on: February 05, 2014, 09:04:56 AM »
There's more to adjusting the headlights on the Interstate.
Reason being once you're on the bike the beams will rise.
Shock absorber setting affects the setting.
With and without passenger will also affect the setting.
Just saying, if you're looking for perfection, you need
to be aware of other factors that will make a difference.
