Tropic traveler
Silver Springs, Florida
« on: February 04, 2014, 04:56:29 PM » |
Well.......... problem is hopefully solved. Swapped the ignition switch from the '97 over to the '98, no change. Turns out after a phone call to TJ he remembered that someone had replaced their starter relay with one of the $11 Chinese ones from E-bay (which I had} & the battery cable mount points were backwards from the OEM Honda. Bingo! Closer examination of the E-bay relay showed the terminals were labeled opposite of the OE. After trying to swap the cables backwards, which did not work because of the offset hole in the cable ends, I just stuck the old OE relay back in & .... we have power!  Immediately rode down to the local Honda shop & bought a new OEM relay {which they price matched HDL btw} and all is good now. Took it for a 10 mile or so ride then came home & started it in the driveway about 15 times. Perfect! You would think myself being a partsman for GM & Ford for the last 27 years I would recognize the value of OEM parts over the cheaper knockoffs but I guess I had to re-learn that lesson the hard way today! Ended up putting the other smaller starter relay I had bought in too. Well, at least I know all the cables & their contacts are squeaky clean, the battery is fully charged & good, the starter button is freshly serviced, & all connections under the RH cover are good to go too. Thanks for all the suggestions & help from you guys & of course the special shout out to TJ... you big walrus!!!
'13 F6B black-the real new Valkyrie Tourer '13 F6B red for Kim '97 Valkyrie Tourer r&w, OLDFRT's ride now! '98 Valkyrie Tourer burgundy & cream traded for Kim's F6B '05 SS 750 traded for Kim's F6B '99 Valkyrie black & silver Tourer, traded in on my F6B '05 Triumph R3 gone but not forgotten!
olddog1946
« Reply #1 on: February 04, 2014, 05:03:31 PM » |
Glad to hear that you've got her back out in the wind...but Jeez you don't need to be calling TJ names, lol..
VRCC # 32473 US AIR FORCE E7, Retired 1965-1988 01 Valk Std. 02 BMW k1200LTE 65 Chevelle coupe, 1986 Mazda RX-7 with 350/5spd, 1983 Mazda RX-7 with FOMOCO 302/AOD project, 95 Mustang GT Convertible 5.0, 5 spd Moses Lake, Wa. 509-760-6382 if you need help
Tropic traveler
« Reply #2 on: February 04, 2014, 05:11:33 PM » |
Hey... Trick Rick started it!  Rick is Fairy Dust & TJ is Chumley from the old Tennessee Tuxedo cartoon.
Thunderbolt
« Reply #3 on: February 05, 2014, 06:07:06 AM » |
Yeah had the same thing happen on Iris's bike. Bought the knockoff and had to modify the terminals on the wire to make it fit. Worked fine for a short time. It died not long after and found a used one on Pinwall. It has been fine ever since. Glad you got it going.
« Reply #4 on: February 05, 2014, 07:09:34 AM » |
I have the green amazon relay in my saddlebags in case of emergency... Which ones did y'all have trouble with?   -Mike
« Reply #5 on: February 05, 2014, 07:59:08 AM » |
Note to Kim; hon, take a piece of tow rope with you next time you guys go riding.  Glad you got it going, I'll bet you won't forget this lesson re. those Chinese parts. On Jay Leno a few nights back he commented about the rover the Chinese landed on the moon. It apparently isn't working right, having some major problems. His remark; the children that assembled it are upset because they worked so hard on it.
Thunderbolt
« Reply #6 on: February 05, 2014, 08:31:24 AM » |
Hey Mike I am pretty sure it is the green one. Problem is that the +12V is on the wrong side. You know right there on the front where the two large wires attach. You can make it work, but you have to cut or file the wire connector to fit because the screw is too close to the center plastic divider. It actually is labeled, but is opposite the OEM. What this does is put the 12V feed to run the bike on the closed or make side of the relay and it will not power up the bike at all. If you reverse the large cables/connectors it will work. It might not be easy to do on the road.
« Reply #7 on: February 05, 2014, 09:22:33 AM » |
I figure if mine (or someone's) ever melts on the road, it will melt the connector too. I'm working on some kind of pig tail to use on the side of the road... I'm waiting on a $5 four-blade plug-in kind of pig tail to show up so see if that might work. If not, I don't see why just making one out of four correctly-sized blade connectors wouldn't be better than walking  ... there's no need for the little cover over the fuse... seems like you just need four properly sized wires ready to plug onto those four blades and splice that back where the melted-and-ruined-anyway plug is on your main wiring harness... I don't have an OEM relay to look at, I hope I can figure out where the wires go when it is time... thanks for the warning... from your post, it sounds like, even though there's four blades on the relay, we only use two? -Mike
Dozer
« Reply #8 on: February 05, 2014, 12:01:40 PM » |
I figure if mine (or someone's) ever melts on the road, it will melt the connector too. I'm working on some kind of pig tail to use on the side of the road... Just a few weeks ago I read an article about how to modify that green relay. The blocks are reversed and I believe backwards. I looked and looked for that article but didnt find it. I know I read it on this forum as a link. I thought it was Chets Rattlebars page or Mark Ts page but I didnt see it there either. It was very clear, concise and had highly detailed pics. If you can find it and modify that aftermarket relay, you'll have a winner. It was a very simple task to do. If someone does find the link please post it so I can save the link.... I'm waiting on a $5 four-blade plug-in kind of pig tail to show up so see if that might work. If not, I don't see why just making one out of four correctly-sized blade connectors wouldn't be better than walking  ... there's no need for the little cover over the fuse... seems like you just need four properly sized wires ready to plug onto those four blades and splice that back where the melted-and-ruined-anyway plug is on your main wiring harness... I don't have an OEM relay to look at, I hope I can figure out where the wires go when it is time... thanks for the warning... from your post, it sounds like, even though there's four blades on the relay, we only use two? -Mike
Thunderbolt
« Reply #9 on: February 05, 2014, 01:39:16 PM » |
Take a look at this sheet from RP's diagrams. See where it says "to starter" the fuse on the cheapo replacement is on that side, no connection to the battery. So the Red wire that goes to your ignition switch for IGN1 and IGN2 never get power. As far as something to get you going on the road as long as you have power to the red wire the ignition should function. Shorting the heavy wire from the battery to the one that goes to the starter with 12V applied to the red wire and she should start. Just make sure it is out of gear. http://www.rattlebars.com/valkfaq/schematics/rpage02.html
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #10 on: February 05, 2014, 04:17:23 PM » |
Glad you got her running Eddie  Electrical issues suck for me to, not my thing. I have had the same problem and replaced with OEM, sorry I forgot to mention that. Come to think of it, I've replaced about everything on my bike. Mine was the worst Valkyrie ever built, although it has been pretty trouble free the last couple of years.
TJ
« Reply #11 on: February 05, 2014, 06:28:19 PM » |
What the hell do you mean hopefully.......................
Tropic traveler
« Reply #12 on: February 05, 2014, 06:54:49 PM » |
Tropic traveler
« Reply #13 on: February 05, 2014, 07:07:59 PM » |
Just to clarify the relay difference, it was the large cables that come from the battery positive terminal & go to the starter that were backwards. While I was on the phone with TJ he mentioned that he had heard of cheapo relays being wired wrong. I grabbed the old OE Honda relay & closely examined the cable mounting points. On the OEM Honda the cable from the battery is on the RH side of the relay, labeled with a "B", and the starter side is on the LH side, labeled with "M". On the cheapo they were reversed. Other than that the relays look identical. As Thunderbolt mentioned the offset of the holes in the cables make it very hard to swap sides.
Rio Wil
« Reply #14 on: February 05, 2014, 07:53:13 PM » |
I thought you would have figured it out by now.....that relay is not incorrectly made. There are a few versions of it that are used on about a thousand different bikes. Look at the pictures on ebay and you will see the B and M markings reversed on many of them depending on their application. Also note many of those sellers indicate the relay is for a Valkyrie with the footnote of check the B and M marks. So you either ordered the wrong one or the seller did not describe the part sufficiently for you to make the proper choice.
Tropic traveler
« Reply #15 on: February 05, 2014, 08:21:01 PM » |
Yep. That's exactly what happened. The listing said all years Valkyrie along with a slew of other bikes. I typed in the Honda OE part number in the search box and..... Then that "assume" thing took over.
« Last Edit: February 05, 2014, 08:22:33 PM by Tropic traveler »
