April 29, 2026, 06:33:36 PM *
Author Topic: Calling John Schmidt...........  (Read 2297 times)
Tropic traveler
Silver Springs, Florida
« on: February 09, 2014, 12:46:12 PM »
Got the carbs put back together with the 38 slows & the pilot screws slotted for easy adjustment. I know you are running the 38's.
Question... before I put the carb bank back on the bike what should I back out the pilots to? They seated real nice with the dab of anti-sieze on the threads. I put an initial 1 3/4 on them.
1997 Valk, K&N with pre-filter, glass pack exhaust, stock main jets.
Thanks in advance!
'13 F6B red for Kim
Thunderbolt
Worthington Springs FL.
« Reply #1 on: February 09, 2014, 12:57:06 PM »
He will give you the straight scoop, but I think 1 3/4 is what has been recommended for the 38's.  2 1/4 for the OEM 35's.  Actually 1/3/4 is recommended as a starting point on the 35's in the book if I remember correctly.  I have my 35's set at 2 1/4 and has been working great.
Flrider
Jack
Kissimmee FL
« Reply #2 on: February 09, 2014, 02:52:16 PM »
I also got the scoop from John when I was doing my carbs, he did say #38 and 1 3/4 turn out..
I am running K&N without pre filter and glass packs.
Happy with the results  cooldude
I am sure John will chime in momentarily and verify   Wink
« Last Edit: February 09, 2014, 02:54:15 PM by Flrider » Logged
« Reply #3 on: February 09, 2014, 04:12:20 PM »
Eddie, sounds good. I don't run the prefilter with my K&N and 1 3/4 was a little lean on a couple cylinders so I went out to 2. Seems to be fine now, been that way for quite a few years. I'd run it at the 1 3/4 and check the plugs a couple times after a good run or two. If they look good, leave it alone.  cooldude
