November 25, 2025, 10:50:52 PM *
Author Topic: ignition pulse generators  (Read 1166 times)
trout dude
Hammond Louisiana
« on: February 12, 2014, 04:40:24 AM »
Dose any one know what size bolts the ignition pulse generators take they were just hanging there when I bought the bike. If I have to I can open mine on my bike and see just trying to avoid that.
  Thanks Dennis
« Reply #1 on: February 12, 2014, 05:30:04 AM »
HDLs fiche page gets suckier every day, but if I squint, I think these
are your bolts: BOLT, FLANGE (6X16)
indybobm
Franklin, Indiana VRCC # 5258
« Reply #2 on: February 12, 2014, 06:44:41 AM »
6 x 16 Flange Bolt is correct. 66 cents each at Partzilla. #32 on the fische. If you use a regular bolt with a washer make sure the bolt is long enough.
So many roads, so little time
VRCC # 5258
trout dude
Hammond Louisiana
« Reply #3 on: February 12, 2014, 07:04:56 AM »
Thanks Mike and indybobm for the quick response That will keep me from having to tare mine apart.
  Thanks Dennis
« Reply #4 on: February 12, 2014, 08:02:04 AM »
In the future when you need to find a bolt/screw size, just go to any Honda parts exploded view and look it up. In the link below, just choose the year then model of bike. Then simply go to the item on the parts list for the exploded view. It will give the diameter and length and whether a flange bolt or not, plus how many are needed for the application on that particular bike. In the example given, it says the bolt is a 6mm in dia. and 16mm long flange bolt.
http://www.servicehondapsn.com/fiche_select1.asp?cat=Motorcycles&mfg=Honda
trout dude
Hammond Louisiana
« Reply #5 on: February 12, 2014, 01:14:39 PM »
  Thanks for that site it will come in handy to put this bike back together.
  Dennis
Big Mike
I can not remember my last bad day
Taylor MI
« Reply #6 on: February 12, 2014, 01:58:35 PM »
Who needs ignition pulse generators anyway? They are way over rated! I just used a distributor! Runs much better now!
Big Mike
VRCC 23871
VRCCDS 0200
With GOD and a good attitude, there is no circumstance that I can not overcome.
OnaWingandaPrayer
« Reply #7 on: February 12, 2014, 03:34:14 PM »
Mmmmm nice!
9Ball
« Reply #8 on: February 13, 2014, 02:00:04 AM »
did you build that bike?
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
indybobm
« Reply #9 on: February 13, 2014, 10:23:11 AM »
Nice picture. Would really like to see a video of the bike running.
VRCC # 5258
