February 08, 2026, 08:32:53 AM *
Author Topic: exhaust manifold stud  (Read 1305 times)
nemo59
« on: February 21, 2014, 12:04:56 PM »
Hi, snapped off a manifold stud left about half inch proud. Think I can get it out, but before I start I wondered if anyone could tell me what the dimensions are of a replacement stud. May try ebay but dont know what I'm looking for. Help would be appreciated. thanks
bentwrench
Philadelphia,Pa.
« Reply #1 on: February 21, 2014, 12:41:24 PM »
The studs need to come from the dealer,they are two different dia.threads. 6 and 8mm
honda p/n90035-MN5-000
« Reply #2 on: February 21, 2014, 01:49:10 PM »
If you are by chance installing the exhaust with new gaskets.....you cannot compress them all at once without risking exactly what happened.  Those nuts are tightened to like 9 ft lbs.....thats not much
« Reply #3 on: February 21, 2014, 05:20:32 PM »
I have yet to use a torque wrench on those exhaust nuts. Just use my 10mm box end to get at the inside ones, snug them up good is all then check them every 100 miles or so for the next few weeks. No broken studs and no leaks.
« Reply #4 on: February 21, 2014, 09:59:08 PM »
7
« Reply #5 on: February 22, 2014, 06:13:12 AM »
I thought it was 7?
Sorry, I almost typed 7 my bad.  Doesnt really matter, this is one of those instances where using a torque wrench is worse than just feeling that its snug.  I dont have a torque wrench that I would trust at that low a reading.....and also I have never broken a bolt on a motorcycle when NOT using a torque wrench....lol
nemo59
« Reply #6 on: February 22, 2014, 08:08:37 AM »
thanks for the info gents much obliged, ta Smiley
« Reply #7 on: February 22, 2014, 10:09:35 AM »
Also, isn't it ft in?    Not ft lbs.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #8 on: February 22, 2014, 11:33:01 AM »
From the service manual:
Exhaust pipe joint nut: 70 N-rn (1 .O kgf-m, 7 Ibf-ft)
So many roads, so little time
VRCC # 5258
Bugslayer
Lubbock, Texas
« Reply #9 on: February 24, 2014, 08:14:23 AM »
I've broken a couple exhaust studs, but not from over tightening. First time I swapped out exhaust, some of the nuts were rusted to the studs. I broke two studs that day. Now I use Anti-Seize on my exhaust studs. I'll check em for tightness a few times after I ride it. Works for me.  cooldude
« Reply #10 on: February 24, 2014, 09:18:31 AM »
WHAT!!!!
