November 25, 2025, 11:29:48 PM
plug wires
Topic: plug wires (Read 812 times)
dryrub
plug wires
February 21, 2014, 01:10:44 PM »
how to take off wires
Last Edit: February 23, 2014, 02:10:19 PM by dryrub
Re: plug wires
February 21, 2014, 01:37:36 PM »
you cannot talk them off....however, there is a write up in shop talk called plug wire conversion....that should help
Re: plug wires
February 21, 2014, 05:21:56 PM »
Yes, check the write-up and use plenty of regular rubbing alcohol. The caps will slip right off once loosened.
ryord
Re: plug wires
February 22, 2014, 06:40:49 AM »
As I recall the plug wires unscrew from the coils and then you can bend the plug tips in such a way as to reveal the internal workings of the wire ( the resistor).
=> InZane XXV
