February 08, 2026, 08:31:26 AM *
Author Topic: Original Honda windshield brackets, do I have them all?  (Read 1074 times)
BigChris99
Hesperia CA
« on: February 24, 2014, 01:34:28 PM »
I recieved an original Tourer windshield win I bought my bike. It is pretty beat  up plastic wise. I also received the original windshield brackets. I have an aftermarket shield on my bike now. National Cycles I believe. I  want to buy a Clearview. I have the straps (?) on the Tourer windshield, I also have one horizontal bar and two vertical brackets. Do I have all the hardware I need to mount a Clearview? If someone would post a picture of what it takes, I could match it up with what I have. Sorry, no pictures of my stuff yet, I'm out the door to work.
In 5th gear.... looking for 6th
VRCC # 35023   IBA # 7849
Bone
« Reply #1 on: February 24, 2014, 02:34:40 PM »
This is off a 98 Tourer. One horizontal and two vertical in this picture.
The verticals go to brackets on the tubes. I have a picture somewhere
of those I'll look.
This came from Shoptalk click on the link for a schematic.
http://www.valkyrieriders.com/shoptalk/GL1/gl64.jpg
« Reply #2 on: February 24, 2014, 02:53:32 PM »
Keep in mind the OEM windshield doesn't mount or use the same brackets that are on the forks.
Bugslayer
Lubbock, Texas
« Reply #3 on: February 25, 2014, 12:28:29 PM »
In case you haven't found the answer to your question, here are a couple pics of a complete stock windshield bracket. This came off my '97 Tourer.
BigChris99
Hesperia CA
« Reply #4 on: February 25, 2014, 12:36:53 PM »
Thank you Bugslayer. I have it all. One more question. Anyone know where I can get the replacement rubber that is on the windshield itself?
« Reply #5 on: February 25, 2014, 12:45:40 PM »
Cheap way out....go to a tire shop and ask if they have an old inner tube they'll let you have. Cut it lengthwise, then lay your parts on it and trace...then cut.
« Reply #6 on: February 25, 2014, 12:45:51 PM »
Likely not available as a single part from Honda, but check the parts fish to see.
Years back, I had to create my own fairing shield gasket, and used thick marine grade vinyl from Home Depot or some builders supply.  Saved the old for a template, easy job.
Probably a number of materials from a builders supply could be used.  Maybe even a small piece (or scrap) of vinyl flooring.
I would try to duplicate the thickness of the original gasket, for windshield longevity.
« Last Edit: February 25, 2014, 12:49:02 PM by Jess from VA » Logged
BigChris99
Hesperia CA
« Reply #7 on: February 25, 2014, 01:37:29 PM »
Thank you all. I have all the information and parts I need.   cooldude
I'll figure something out for the rubber. And keep the old for templates.
« Reply #8 on: February 25, 2014, 01:54:04 PM »
Is the old gasket messed up? I've reused it over and over, on two sets of
hardware...
« Reply #9 on: February 25, 2014, 03:41:51 PM »
hardware...
As you probably know, those gaskets are expensive!  Shocked
My rides:
BigChris99
Hesperia CA
« Reply #10 on: February 26, 2014, 02:35:54 AM »
I don't know if the gaskets are messed up or not. I put the Honda windshield away a few months ago. I'll get it out this weekend,it's supposed to rain all weekend anyway, and take a look.
