February 08, 2026, 08:31:23 AM *
Author Topic: K&N Air Filter  (Read 1510 times)
robin
Get on it and RIDE!!
Hardwick NJ
« on: February 25, 2014, 01:57:02 PM »
Do you put the foam pre filter in?
Bota58
Oakland City Indiana
« Reply #1 on: February 25, 2014, 02:31:28 PM »
Hi,most people that I've talked to have left them out especially if they have rejetted the carbs,I've got mine out also.
Life's Journey is not to arrive at the grave safely in a well preserved body but rather to skid in sideways totally worn out  shouting holy cow what a ride!
« Reply #2 on: February 25, 2014, 02:34:18 PM »
Yes, it is called for in the Valk application.
It could cause a lean condition without it, but hundreds here run it with no prefilter so maybe not.
I always err on the side of protecting my bikes.
Recall the recent discussion about fine particles flowing thu the K & Ns, and how many (like me) go a year or two between tank pulls (and reoiling)?  My prefilter gets pretty dirty, between tank pulls (and I spray it with brake cleaner and stomp on it to clean).
A dusty riding environment is also relevant.
« Last Edit: February 25, 2014, 02:41:22 PM by Jess from VA » Logged
« Reply #3 on: February 25, 2014, 03:37:54 PM »
+1  cooldude  I prefer the prefilter because my Valk will run lean and backfire on decel.
My rides:
« Reply #4 on: February 26, 2014, 03:27:25 AM »
K&N lets in a lot of dirt, google the reports/testing even k&ns own testing proves this if one understands the SAE test they use. search for the spicer test.
the oem filter is good for 20-30k miles, (changing at 12k is an industry std since the manufactures do not know what conditions a vehicle will be driven in like the 3k miles oil change only true about 10% of the time) and flows more than enough air to make 100 dyno hp on my bike.
I have over 20k on my oem filter, no change in performance, mpg or plug reading.
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #5 on: February 27, 2014, 03:34:48 PM »
The K&N didn't do anything for my diesel pickup either. Just let more dirt in.
« Reply #6 on: February 27, 2014, 03:43:48 PM »
http://home.roadrunner.com/~jbplock/ISO5011/SPICER.htm
actual test showing how bad a K&N is. the K&N is a race track item that shouldn't be used on the street.
www.bobistheoilguy.com  plenty of oil analyisis results of high dirt levels when a K&N or one of the other cotton type filters are used.
« Reply #7 on: February 27, 2014, 03:44:55 PM »
I have mine in.
Tropic traveler
Silver Springs, Florida
« Reply #8 on: February 27, 2014, 06:19:28 PM »
I talked to a K&N rep several years ago about the pre-filter. He said that a K&N with the pre-filter flows roughly equal to a stock paper filter.
I have had a K&N with pre-filter in my '97 & it does keep the air clean judging by lack of residue on the inside of the housing. Still do not trust any oiled gauze filter in turbocharged applications.
'13 F6B red for Kim
uturn
bayou vista, texas
« Reply #9 on: February 28, 2014, 04:30:09 AM »
hmmmm y'all got me thinkin that next wrench party i might throw a paper one back in there and see how it runs. i have the bare k&n, i put 38's in for slow jets and all my cool decel backfire went away. maybe the paper will lean it up just enough to reinstal my deceleration alarm?
bentwrench
Philadelphia,Pa.
« Reply #10 on: February 28, 2014, 05:56:13 AM »
I had a K+N in mine w/o pre filter for 25k miles.At that milage it had picked up less dirt than the stocker did at 10k.So I put an o.e. filter back in.About 12k miles later I sent an oil sample to blackstone along with some fleet samples from work.The lab gave a glowing report for the valk. stating  wear  metals were much lower than most engines let alone mtr/clutch/trans combo.One thing they made a note about was a silica level slightly higher than expected(dirt?)though not in the harmful range.
I'm sticking with mother honda's filters,this one is a keeper.
BW
« Reply #11 on: February 28, 2014, 07:49:43 AM »
I bought a half dozen oem filters cheep at a swap meet, all new and in the box, about 9 years ago.  I have 2 of them left after 90,000 miles.  I like em.  Hoser    cooldude
