February 08, 2026, 10:23:32 AM *
Author Topic: REPLACING STANDARD TANK WITH I/S TANK... ANY POINTERS?  (Read 1224 times)
Paxton
So Cal
« on: February 26, 2014, 07:22:15 AM »
My new-to-me I/S tank is in transit. Cheesy laugh cooldude
Is there anything different that I must do for a successful swap... like changing the seat, replacing rubber supports, etc. Embarrassed
Would all the hoses and hardware from one tank fit the other? Undecided ???
Thank you for your comments.
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
Joe Hummer
Arnold, MO
« Reply #1 on: February 26, 2014, 07:36:11 AM »
As you indicated, the seat will probably need to be changed out.  Usually the IS Seat will work on the Tourer/Standards with a little more gap between the seat and the tank but the Tourer/Standard seat does not work (well...anyway).  If you have a aftermarket seat, such as a Mustang, I think you are good to go.  I am not sure about the other seat makers.
The only other thing you are going to need to do is block off the level sending unit.  There used to be a plate available for this purpose but I do not know if it is still available.  As an alternative, you can just leave the sending unit in place and just don't connect the wires (you don't have a place to plug them in anyway on your bike).
Otherwise, everything else should be plug and play.  Petcock, vent line, gas cap will all fit on the new tank.
Joe
1999 Valkyrie Interstate
Paxton
So Cal
« Reply #2 on: February 26, 2014, 07:42:08 AM »
"... block off the level sending unit.  There used to be a plate available for this purpose but I do not know if it is still available."
Joe, the tank comes with the block-off plate already installed. cooldude
J. Paxton Gomez
So Cal... 91205
ptgb
Youngstown, OH
« Reply #3 on: February 26, 2014, 08:17:00 AM »
The wife's 03 Standard (Trike) has a I/S tank on it.  Used the OEM seat for two years. No problems whatsoever.
Just received a Russell Day-Long for it made from the OEM seat pan.... also no fitment problems.
« Reply #4 on: February 26, 2014, 08:19:42 AM »
If you use a seat made for the Std. or Tourer, the nose of the seat will abraid the tank. Get some clear shipping tape used on boxes, etc., and stick it to the tank area under the seat nose.
« Reply #5 on: February 26, 2014, 05:34:36 PM »
Just to be clear, Mustang is the only aftermarket seat maker whose seats are interchangeable between std/tourer and interstate.  Any bigger nose std/tourer seat should snap down with an IS tank, but may/will rub the tank and/or kink the nose of the seat up a bit.  Either protect the tank with tape (under the big nose), or get your seat nose trimmed at almost any upholstery shop, or maybe do it yourself (pull a couple staples only at the nose, pull only the cover around the nose back, file/cut a bit of material off, pull the cover back tight, and staple it back under the lip)
CAVEAT:  Corbin seats are filled with concrete, so I don't know if their std/tourer seats can even be made to snap down on an IS tank.  Roll Eyes angel
« Last Edit: February 26, 2014, 05:39:58 PM by Jess from VA » Logged
Paxton
So Cal
« Reply #6 on: February 26, 2014, 07:11:58 PM »
Got a new Mustang Solo. Beautiful, but it does not take a backrest and it is about 1" taller. Roll Eyes
I'll try it again. It looks pretty good.... just a little too high for me. Embarrassed
I travel across the USA with a Corbin on my I/S. It looks good but literally a pain in the ass!  Lips Sealed
J. Paxton Gomez
So Cal... 91205
RONNIEB
NEWCASTLE, OKLAHOMA
« Reply #7 on: February 27, 2014, 02:40:13 AM »
TOO MUCH WORK!!Just donate your IS tank to me. HAHA
1999black standard; 2000 black tourer; 1999 red/black interstate
rhinor61
Northern California
« Reply #8 on: February 27, 2014, 08:29:56 AM »
Paxton...
You will have the block off plate, just install your gas cap.
Make sure the vent tube is clear, just blow some air thru it before putting on the bike.
Maybe a good time to rebuild your fuel shut off valve or replace with a pingle shut off..
I you decide to run the velocity stack, you will have to shim the front of the tanks about 5/16", that creates a new problem because the tank is no longer sitting on the frame/pads.
 So you can pick up some water pipe insulating foam that will go over the existing frame pads. Its the 360 pad with a split in the middle to wrap piping.
Sounds like you got the seat conceren already addressed.
enjoy..!
« Last Edit: February 27, 2014, 08:31:52 AM by rhinor61 » Logged
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #9 on: February 27, 2014, 10:09:02 AM »
Hey PTGB  if you dont mind could you Enlighten me as to what you got with your Russell, IE: just driver or passenger, also back rests, rain covers , heaters etc. ?
and HOW MUCH   Undecided  I am thinking about upgrading and after searching the reviews I am leaning HEAVILY towards the Russell Day long.
Wewa
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
« Reply #10 on: February 27, 2014, 12:22:24 PM »
OEM '98 std seat w/ButtBuffer installed, no problems with my I/S tank, been on there for 30k miles.
ptgb
Youngstown, OH
« Reply #11 on: February 27, 2014, 04:50:03 PM »
Hey PTGB  if you dont mind could you Enlighten me as to what you got with your RussIEell, : just driver or passenger, also back rests, rain covers , heaters etc. ?
Wewa
First off, I'll say that I am probably a Russell Daylong sycophant... I consider them the best seat on the market, bar none.
I have had them all... OEM, post-2000 OEM, Mustang, Corbin, Ultimate. Once I got my Russell, I have never looked back and every motorcycle I own (that I use to travel) will have a RDL. I have put over 30,000 miles on my Russell... still love every minute of it.
On my Interstate I have a rider/passenger combo. Leather on top, vinyl on the sides. Have the rain cover, worth it with leather so I'm not sitting on a wet seat if the Valk sits out in the hotel parking lot in a storm. No backrest, I have never liked them, I feel that they push into my lower back... I slouch in the seat a lot. That one cost right around $750, I think.
On my wife's Standard (Trike), we just got her a leather/vinyl driver seat only with cover. That one cost $600. No backrest for her either.
The seat is made to conform to your height, weight, inseam, etc. It definitely isn't a marketing ploy IMO as I have done 1000-1500 mile days on the RDL with NO discomfort whatsoever.
The custom making of the RDL to you makes for sometimes having to wait to get one. For mine, I sent in my dimensions and pictures in January. They gave me a "build date" of mid-March. So I had to wait 2.5 months for them to start it and then it took them a week to build it and another week to ship it back (CA to OH). Got it in mid-April. You have to be patient when getting an RDL. That being said, for my wife's, I sent in the order and they wanted the old seat the next week and I got it back in two weeks after that... about a month total. Spring is a busy time for them as people are getting seats for riding season.
« Last Edit: February 27, 2014, 04:53:04 PM by ptgb » Logged
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #12 on: February 27, 2014, 07:01:32 PM »
First of all,  Sorry Paxton for jumping in your post .
Second of all  Grin.  Thanks Ptgb  for the info, you have persuaded me with your input.
Third of all  Paxton,  you can have it back now 2funny
Wewa
